Whirlpool S20DRSS33 Side by Side Refrigerator
Problem for Whirlpool S20DRSS33 Side by Side Refrigerator
Water Filter Indicator
By jilly ll on Aug 01, 2007
The water filter indicator keeps flash at 1% even though I have change to a new filter. How do I get it to change back to F99%
Comments:
Aug 10, 2007
- Thanks for that, tried what was suggested but it didn't work on this model, but I didfind the solution using this method. On this model you need to press the OK button on the door display panel 5 times in quick wihtin 10 seconds to get it to change.
Any way thanks again for the inspriation.
Same Problem
Feb 02, 2008
-   Hi, I have the same problem with filter indicator flashing at 1%. I tried all that was suggested, but still no luck. Any other solutions?-   Tanial1967
Best Solution
posted on Aug 01, 2007
Helpful)
sgregg
Rank: Guru
Rating: 89%, 237 votes
The water filter status light, present on some models, will help you know when to change your water filter. The light, or indicator, is located on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door. The light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red OR when water flow to your water dispenser or ice maker decreases noticeably.
Most models also have a Filter Indicator Reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button. The status light will change from red to green when the system is reset.
If your model has a water filter indicator but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
also here is a link to the site for pics
http://whirlpool.custhelp.com/cgi-bin/wh...*&p_li=&p_topview=1
Was this helpful?
Yes
No
Solution #2
posted on Apr 06, 2009
Very Helpful)
lyall73
Rank: Apprentice
Rating: 100%, 2 votes
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Whirlpool S20DRSS33 Side by
Questions and Unsolved Problems for Whirlpool S20DRSS33 Side by
Do you recommend Whirlpool S20DRSS33 Side by Side Refrigerator?
Answer
Answer
Hello, i Got a Problem with my S2OD RBB32-A/G Whirlpool Ref. its has a Fast and Random Clicking on... (More)
Answer
no more ice, I'm looking for the notice Regards Olivier
Answer
Hi, I have a Whirlpool S20DRSS33 Fridge Frezzer which has been making a chattering noise for a while... (More)
Answer
Regularly the fridge alarm will sound and the letter d appears in the fridge side temperature... (More)
Answer
unit is only 4 years old. paid 160.00 to replace compressor relay.made 2 batches of ice and stopped.... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , AK
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
