I have a Toshiba L645-S4102, all systems are working, but my screen turns down the brightness and resolution when i try to maximize any window. Only the right side of the screen shows this low resolution problem but the left side is perfect. The problem appears exactly at half of display and the only way I found to correct it, is restoring my screens to minor size than maximized or close and open my screen a few times. Please help me. I can't find a flex cable for this laptop, usually that's the solution on most computers but i don't want to purchase parts I will never need or not solve my problem. Toshiba Satellite L645-S4102 Windows 7 Home Premium 4Gb Ram Memory, 500 Gb HDD [email protected]
SOURCE: Maximizes & minimizes screen while scrolling or using pointer on Vista
change mouse out buy replacemnt goes under the plastic housing not to bad to change 20 bucks on ebay
SOURCE: how can I restore my Toshiba L305D-S5895 laptop
You should be able to boot the computer from the operating system recovery disk. Most likely your harddrive crashed, or one of (many) other issues. It could have just erased your MBR, in which case you can boot with a live cd and recover most (if not all) of your data.
SOURCE: HI I don't Have a
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state.
6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
SOURCE: How to solve Toshiba satellite L645 From black screen ?
You may have a faulty inverter, it supplies high voltage to the CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Test all leads that attach to your hard drive including electrical extensions EIDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure dust free connections and are not faulty or just replace them they might be faulty
you might have a dirty graphics card if you remove your graphics card clean both card and socket restart your computer then reinstall it this should activate found new hardware wizard
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if your computer came with a motherboard disc the drivers could be on it
or you might try these
http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance
hope this helps
