Question about Water Heaters
Central haeting keeps turning on when itself
Thermostat is set correctly but just keeps turing itself on every 20 mins or so.
  • Ron Krysiewski May 11, 2010
    What kind of heating system do you have. Warm Air "vents in floor", Steam "radiators", Forced Hot Water "baseboard along the walls"?
  • Allen Neal
    Allen Neal May 11, 2010
    what type thermostat and heat are we talking here
  • 88 Answers
Change your air filter, if the system has to work too hard, it will over heat. If the filter is allowing air flow and the system still shuts off it is the thermostat. Keep in mind the Thermostat gauges the temperature where the thermostat is located, if its next to a running fireplace it will think your entire house is that temp.
Posted on Apr 18, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
I have a honeywell thermostat, It keeps blowing even when I try to turn it off. Could you please tell me what is wrong with it? And can I fix it myself?
Do the easy stuff first! Is this a new install or has it been working well for a time and now it is not? Is the entire unit continuing to run or just the fan? Thermostats generally turn the unit on and off when the desired temp is reached but the fan itself (not the compressor or heat strips) typically operates in 3 modes, off, on or auto. check the fan setting.
Nov 15, 2014 | Honeywell TH5110D1022 Focus PRO 5000...
Central heating not working but hot water is ok.
If when you turn power off you wait a while it is probably not the central system coming on. You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in. try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 13, 2014 | Water Heaters
Wire wilo pump
Check your thermostat wiring, it sounds like you have it set up for cooling.
Mar 07, 2014 | Water Heaters
How do I turn on the central heat in a kz jag rv
Turn on your propane and set thermostat to heat and adjust temperature. It should all start on it own, as long as plugged in or fully charged battery connected. If it doesn't fire up first few tries, shut off and try again as it may take a few times to purge propane . If no AC on unit and thermostat is for heat only, there may be a lever on bottom side of thermostat to push over for on, then set thermostat temperature. If any problems, get back to me and I'll walk you through it.
Feb 13, 2011 | Water Heaters
The water temp is set to the lowest thermostat setting; however, the water is extremely hot and often throws the safety breaker loaded on the heater itself...... I reset the red button and it heats.........
probably has lime and mineral deposits on thermostat and is not getting a correct reading turn off water supply and electrical - drain tank remove screws to heater elements and if build up try cleaning or if to bad replace same with the stat
Feb 15, 2010 | RELIANCE ELECTRIC WATER HEATER
Thermostat keeps cutting power off to elba excellance oven
I have a similar problem with an Indesit oven. There are two thermostats one controlling the oven temperature which i think you have replaced and another over-temperature stat to prevent the oven getting to hot should the temp stat fail to control the temperature. The over- temperature stat could be operating to quickly and this cuts power to the the digital display, oven light, temp light and circulating fan. I am going to replace this over-temp stat
Jan 18, 2010 | Lux Elba OV 5085 LUX
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Honeywell wall thermostat
Hi,Richmart
I'm Harvey the Plumber,
First, Your question is if your thermostat is wired correctly!
Assuming that it is correct, a common problem that most people and plumbers overlook is correctly setting the heat anticipater on the thermostat.
Assuming that you have a gas central heating system, then you must simply look on the gas valve for the amp rating.
For instance,if the gas valve printing says .4 amps then set the heat anticipater for .4
It's common for the unit to turn on and off erratically (short cycling) when this setting is not correct.
If all you are worryied about is the wiring, you must look at the wireing diagram that came with the thermostat.
Further diagnoses would requie detailed information about your central heating system.
Or the alternative would be to have a hands on tech help you out.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey
Sep 07, 2008 | Water Heaters
Water Heaters Logo
76 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
