Question about Toshiba Satellite A135-S4527 Notebook
Need instructions on how to install disk drive into laptop
Ok first off i have so many probs with my comp it is so lame.with that said i am attempting to repair my disc drive because my burner made a funny noise and gave up(will burn about 20% of disc) so i bought the internal disc drive in hopes that this will solve that prob.but before i take anything apart-which usually results in disaster- i am hoping i can get some kind of step by step instructions or advice.my laptop model# is a135-s2386 the part # is k000045650 i use vista home basic if it matters.if you are an expert in this kinda stuff please contact me cause if you cant help me with this prob i have so many more.and the aholes at toshiba will not help me at all.thank you everyone
  • 382 Answers
OK first relax and breath. Now here is a site that should help. I hope that is the problem, I have seen some programs that also cause same type of problem. I wish you luck and hope this helps. Have a good day.
http://www.irisvista.com/tech/
Posted on Feb 02, 2009
My comp doesnt instal xp.a hard disk error appear after loading files.systemroot>system32>config.i had instaled 2 copies of the said xp sadly i mistakenly deleted part of the xp.help coz my comp is...
you need to do this on a brand new low level formatted, and high level formatted hard drive. you must have the install disk, and a internet connection, and a properly running system available to work along side.
You can reformat this old drive; however, personally, I wouldn't bet on using it. hard drives are cheap these days. let me know.
Sep 16, 2012 | Computers & Internet
Dvd not recognizing discs
it could be that your drive needs cleaning with a cleaner disc that you can purchase quite cheaply. If your a smoker or use your comp in dusty conditions this is probably the case. You haven't stated if your comp actually sees the drive before you insert a disc (also check the drivers are installed in your device manager), look in my computer and look for the dvd drive prob "D" if it does see the drive and the drivers are ok then you can if you are very gentle use a cotton bud to clean the laser lens (slightly damp) but you must be gentle, this of course is if you are using a laptop that you can see the lens on when you open the drawer. If it is a desktop then its a cleaning disc, it might work, it might not.
Mar 10, 2011 | Computers & Internet
I have forgot my password and i can not log on to my laptop what can i do ??
You will need another computer that can burn CD's, and obviously a blank disk
Follow THIS LINK and read the article/reviews on the top Windows password recovery applications. Once you choose the one that's best for you, download and install it on Comp #2, follow the instructions and burn the .iso file to a disc.
Access the BIOS on Comp#1 (the one you can't login to) and set the boot order so that the CD/DVD-RW drive is first. Insert the CD you made, and reboot Comp#1. The CD will automatically do it's thing.
Nov 06, 2010 | ASUS Eee 4G Notebook
Probs running loaded program (ceasar III)
Not a hardware problem. Either the game was badly installed - the security software on your computer has most likely blocked the DRM from your disk - or the disk is worn out and the new optical unit can't pick it up - use the older one..
Jan 05, 2010 | Electronics - Others
My laptop is really slow
It could be due to clogged Registry. Use a good registry cleaner to do that. Even I had the same prob. my laptop used to take 20 mins to boot. After cleaning the registry it runs now.
Sep 17, 2009 | Gateway MT3705 Notebook
No iede found
is the hard drive showing in bios? you may have a hd too large for the bios to read. has it been fdisked or formatted?how large was the od hd? was it the same type hd? either way when you reload the operating system you will need a disk. post back and let me know, i will try and help. just the info you gave is not enough to attempt repair.
Jul 19, 2009 | Compaq Presario R3000 Notebook
Operating system not found
This means it cannot find the Windows OS files because either:-
The hard disk has failed or it needs reseating.
or the hard disk controller has failed.
or the Windows files have been deleted or corrupted (maybe by virus)
Try reseating the hard drive.
If the hard disk is faulty, you need a new one.
Try using your recovery CD disk.
Try re-installing Windows
Feb 24, 2009 | Acer Aspire 5050 Notebook
A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Jan 25, 2009 | Dell Latitude C400 Notebook
ASUS EEE 1000H fails system recovery procedure
Shut down Comp. Hit F2 continually whilst powering up. Now go to boot up and make dvd boot first choice.
Save the settings and exit.
Unit will auto start restore.
Follow actions and don't try to rush things.
Dec 16, 2008 | ASUS Eee PC 1000H Laptop
Toshiba Satellite A135-S4527 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
