Question about Seagate 9w2874-500 200 GB Hard Drive
Compaq armada stuck on help menu
When i turn on my lap top,it starts to boot up on windows xp but then goes to black screen with help menu.It says we apologize for inconvience, but windows did not start successfully. A recent hardware or software change might have caused this.
If your computer stopped respondin, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose Last Known Good Configuration to revert to the most recent settings that worked.
If a previous startup attempt was interrupted due to a power failure or because the Power or Reset button was pressed, or if you arent sure what caused the problem, choose Start Windows Normally.
And then menu.
I can get into f10 and f1 but i dont know what to do? i tried all the menu buttons, any help or advice much appretiated.
Thanks Karen,
  • karen_dublin Feb 02, 2009
    Thanks for quick reply :),I am now on blue screen window saying unmountable boot,i dont know how to remove software or hardware,I am really bad with this but learning,I already tried last known configuration and safe mode but it didnt work.How do i remove software or hardware please
    Thanks alot
    Thanks alot :) i am turning off now and plugging out and removing battery.
    It a compaq armada m700
  • 63 Answers
Try selecting safe mode, remove the software/or updates you recently installed
or choose last known good configuration.
If that does not work, you can choose F10 and restore your OS
Posted on Feb 02, 2009
  • Kim Tyler Feb 02, 2009
    unplug all devices except power, take out your battery, and try to start it again
    otherwise...you can try to use the F10 when you turn it on...this will give you the option to restore the computer to the way it was when you bought it.
    when you have done that, and it still wont boot up, you most likely have a hard drive problem. since it is a compaq, you may be able to test it in the bios (F2) select boot devices, and test
    what kind of Armada is it?
How to get to safe modem?
Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode- If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen
Jan 14, 2012 | Compaq Armada M700 Notebook
When I move my compaq lap top or type a key too hard
that sounds like a video card error. if you can disassemble the notebook, check for loose connectors, particularly the connector that goes to the screen.
Apr 27, 2010 | Compaq Presario Notebook
Windows xp was installed on a compac armada 1750 was worling fine but after an hr or so it shut off and now wont boot or run windows all i get is black screen with window xp and 30 sec coutdown and......
On *********** board, there will be a battery, take that out and put it back in. if you have the OS disk. put it in. shut off computer, turn it back on press enter to boot from disk. either re format your hdd by deleting the partioned space or repair.
Apr 11, 2010 | Compaq Armada 1750 Notebook
OS does not work in pc
The Windows 98 option seems to be DOS-only. You could try typing WIN or WINDOWS at that C:\> prompt.
For Windows XP, you can try a few things:
1. Boot into Windows XP, but hit F8 BEFORE the splash screen (with the scrolling bar) appears. You will get a menu. Try Start with last known good configuration. See if it boots. If not, repeat, but choose Safe Mode. If it will not boot in Safe Mode, you have a more serious problem. Continue to 2....
2. Insert your Windows XP CD in the CD-ROM drive (you need to have your BIOS set to boot from CD first, or look at the POST screen for an option that lets you select boot device). If it asks, press a key to boot from CD. Let it load. First off, try pressing R to go into the recovery console. Follow the instructions. When it asks you which Windows you want to log on to, choose the appropriate one. When it asks for a password, try just pressing Enter (return). If that works, you will get a prompt similar to the Windows 98 screen. Here, try the following:
CHKDSK /r
(this will take a while - just leave it. Note that you may see it restart the % count up to 5 times. You'll get a report the prompt again when it is finished. Hopefully it says it repaired one or more errors)
FIXBOOT
(say Y to the question)
Now reboot. If you get the menu screen again, don't choose safe mode or last good configuration, choose Start Windows normally.
If this doesn't work, you either have a badly damaged Windows install or a hardware fault. You could try booting into the Windows CD and doing a repair install. Where you pressed R before, press ENTER. Follow the on-screen instructions - you want to do a repair install.
Apr 20, 2009 | Computers & Internet
My Compaq armada will not go to windows
well, do that then, you ansewered the question =)
Feb 02, 2009 | Compaq Armada M700 Notebook
My lap top shuts it's self on am off
Try removing the battery and starting up only on AC power. You may have a faulty battery. It could also be the power supply or a bad memory chip. If it's none of these, then it's a motherboard problem.
Jun 20, 2008 | Compaq Armada E500 Notebook
My Screen Is Black When I turn the Laptop On
need a inverter maybe. t23 lcd inverter check ebay diy project need a screw driver thats it
Apr 14, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Start up problem
it is struggling to find the boot.ini, you can try pressing F8 when it's booting up and then you should get into safe mode, when in select last known good configuration and then press enter for a reboot.
If you still cannot get into windows you will need to perform a system repair, borrow a friends XP disc, but use the key code normally on the underneath of notebooks of your own system if you have one, then set your cdrom as first boot device in the bios (F2 or Del on boot up) and then insert the disc, then press enter to boot from cdrom and press R for repair when prompted.
Oct 15, 2007 | Compaq Armada M700 Motherboard
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Stuck on the Windows XP Welcome Screen
One of an important file needed to boot up your laptop, or your hardware is loose. Try taking out the ram and putting it back in.
Aug 28, 2007 | Compaq Armada M700 Notebook
Seagate 9w2874-500 200 GB Hard Drive Logo
73 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
