Question about Logitech PS2 BLACK OPTICAL WHEEL MOUSE (9536950403)
My logitech ps2 mouse gets hanged while working
My logitech ps2 mouse gets hanged and the cursor also gets jammed on the screen while working in windows xp at my home. This same mouse works smoothly on the office pc with windows xp. cant work from home since 2-3 days.deep problem .please help
    Sniper:
  • 54 Answers
Sounds like the driver has become corrupted. You will have to uninstall then reinstall the drivers. Lets start with that, let me know how it goes and we can take it further.
Please remember to rate me.
Posted on Feb 02, 2009
My cursor is stuck in the middle of my screen on my computer, my mouse is wireless so i tried changing the batteries and using every USB port and still nothing. I then got a wired mouse and tried that in...
Sounds like USB stopped working(maybe driver related). Try booting into safe mode by pressing f8 at startup before the logo screen for windows appears. If it is working in safe mode then it is not hardware but rather driver related. This also sounds like an older computer that might have a ps2 mouse port. If you have an old ps2 mouse you can try that.
Aug 14, 2017 | Microsoft Comfort Optical Mouse 3000...
Cursor stuck in the middle of screen vista operating system
What are you using? a laptop or a PC?
If you are using a PC then check that the mouse is connected properly to the slot. Also check the ball inside the mouse, it happens sometimes when its dirty, clean the ball inside the mouse and also inside the mouse(use a small cloth).
If you mouse is wireless then check the battery in your mouse. It might run out of charge. Also check the button which is used to turn on the mouse. It might be jammed.
If its a touchpad there is no solution that I can think of other than buying a mouse.
Aug 14, 2009 | Logitech Cordless Desktop EX110
Logitech mx518
To work around this problem, turn off the Enhance pointer precision feature: 1. Click Start, click Run, type control mouse, and then click OK. 2. Click the Pointer Options tab, click to clear the Enhance pointer precision check box, and then click OK.
Also see this article from Logitech.
The surface on which you use the mouse plays an important role in its tracking. The optical sensor must use the pattern on the surface to track the position of the cursor. Therefore, using the mouse on a glass or otherwise see-through surface will inhibit the ability of the sensor to track the cursor. Also, if you are using the mouse on a reflective surface, such as a mirror or shiny metal desk, you may experience tracking problems. In both these situations, try using the mouse on a mouse pad or piece of paper. By using the mouse on a white sheet of paper, you can also conserve battery life. Other surfaces that have been known to cause tracking problems are:
  • Some wood grains
  • Grooved surfaces
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 22, 2008 | Logitech MX518 931352-0403 Mouse
Logitech MX620
Greetings,
There is nothing wrong with the mouse and if you install another new mouse it will most likely do the same thing. Here is what you do. Assuming you have windows click where it says start at the bottom right of your screen. Then click on the option "control panel" If you have windows xp you will click on "printers and other hardware". Then click mouse. This should bring up a picture of your mouse and a tabbed menu. You will go to the tab that says motion and you will be able to adjust the cursor speed via a sliding bar. Let me know if you need any more guidance.
Take Care
-WN
May 22, 2008 | Logitech Cordless Mouse
Cursor sliding off screen
I?ve had this problem in several Logitech mice. In every one of my cases the problem was resolved by uninstalling the driver and reinstalling the latest OR just using the default Windows driver. In some cases with USB mice I had to shut down the PC, remove the original mouse and replace with a standard PS2 mouse, remove and reinstall the driver and then reattach the USB mouse without rebooting. After a successful test you can shutdown the PC and remove the PS2 mouse. Let us know if that works and if you have any other questions and thanks in advance for rating this post.
Apr 01, 2007 | Logitech Cordless TrackMan Optical...
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
Computers & Internet Logo
183 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
