I can not uninstall my sql from my system. when i tried to uninstall it, it shows the following error unable to locate installation log C:\mysql\uninst.isu
  • Dan rogers
    Dan rogers May 11, 2010
    The other option is to delete the program manually by finding all the files and folders that contain this program. or try to open the folder in the start menu and see if you can uninstall from there
    Novelist:
  • 210 Answers
If that file really isn't there (you can have a look), you can do the above suggestion.. manually remove it. (which won't really remove ALL of it).
I find the laziest way is to reinstall the same version again, then immediately uninstall it. The reinstall puts back files that the uninstaller needs to get rid of it. Stupid? perhaps. Works? sure does! =-]
Posted on Feb 05, 2009
How do I recover data from .mdf file
Detach you database. Overwrite the mdf and ldf files you've restored from your backup with your files from the D: drive. Reattach the database.
There is no guarantee that this will work or if it works, that your database is in a state where you can continue to work with.
If that doesn't work then there is an option to try to restore database using SQL Server Recovery Toolbox. It is a powerful tool for data recovery. They have a demo version. So you can check it works in your situation or not.
http://www.oemailrecovery.com/sql_repair.html
Jan 19, 2016 | Microsoft SQL Server 2008 Enterprise Full...
Tip
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
Tip
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
Attach a database without the corrupted log file
There might be other options out there. This is something that worked for me once but there are no guarantees that it will work at all times.
Stop SQL Server instance -> Copy MDF and LDF files to another location -> Delete original MDF and LDF files -> Start SQL Server instance again -> Create new database with exact same name and file names -> Stop SQL Server -> overwrite newly created MDF and LDF.
After this your database should be back online. If it is then go ahead and put it into EMERGANCY mode and SINGLE USER mode.
Finally go ahead and execute DBCC CHECKDB like this
DBCC CHECKDB (databaseName, REPAIR_ALLOW_DATA_LOSS) WITH NO_INFOMSGS
More information you can dig out from resources directly connected with SQL Server databases and database corruption in MS SQL Server any version...
http://itknowledgeexchange.techtarget.com/itanswers/how-to-restore-mdf-file-as-bakcup-databe/
https://www.repairtoolbox.com/sqlserverrepair.html SQL Server Repair Toolbox
May 15, 2015 | Microsoft SQL Server 2008 Enterprise Full...
Hay Bahratt, I have uninstalled the 3 SQL programs in the control panel a few times with no effect on the issue. I didn't try moving directory C:\Program Files\Microsoft SQL Server\MSSQL to another...
If you have removed it from control panel, its done. You just have to clean up any left over registry entries using CCleaner and then try installing again
http://www.ccleaner.com/download
You may also want to check out this microsoft link if it doesn;t work
http://office.microsoft.com/en-us/help/HP011128601033.aspx
Jan 10, 2010 | Computers & Internet
Error installing MS Office pro 2007 with BCM
Uninstall from control panel the following:
Microsoft SQL Server native client
Microsoft SQL Server Setup Support files
Microsoft SQL Server VSS writer
Move directory C:\Program Files\Microsoft SQL Server\MSSQL.1 to another location for possible use. Delete everything under Microsoft SQL Server in c:\Program Files
Reinstall
Jan 10, 2010 | Microsoft Office Professional 2007 Full...
Im not able to instalthe primavera p6 on my new hp lap windows 7
Before installing primavera p6, check whether any SQL databases with the same name exists. Uninstall the SQL if the databases created during the previous failure installation of primavera p6(go to add or remove programs to uninstall). After uninstallation of SQL express, try to run installation files for primavera p6 will solve your problem.
Revert back for more assistance.
Dec 26, 2009 | Computers & Internet
When booting the system the following error message appears: SQLDUMPER failed initialization
the uninstall tool vs_uninst.exe located at http://download.microsoft.com/download/0/a/a/0aacd9c1-a0c5-43ab-a428-0ee440d4472c/vs_uninst.exe.
this error usually occurs when removing certain Microsoft products, or when using the SQL server. Here is a few articles which may help you correct your issue. First, it is a forum where an individual has a similar issue, and the help offered:
http://www.sqlteam.com/forums/topic.asp?...
Next, a Microsoft Knowledge base article on the SQL sqldumper utility, and some troubleshooting techneques:
http://support.microsoft.com/kb/827690
The next page is the SQL tech support and has different errors which can be generated. Look down the list and see if you can locate your particular error and when/how it occurs:
For SQL 2000:
http://www.gridview.org/kb/SQL2000/defau...
For SQL 2005:
http://www.gridview.org/kb/SQL2005/SQLSe...
May 13, 2009 | Microsoft Windows XP Professional for PC
Try to type my username and password in and error message shows
hi there hey it looks to me like you may need to go to device manager and uninstall the device and than turn off the computer and reboot the computer and you will see the new hardware found pop up on the taskbar just let it reinstall it and it will tell you that the device has been installed and is ready to be used now you should be able to log onto it as normal . best regards mike
Jan 14, 2009 | Dell Dimension 4600 PC Desktop
Unable to create database from within VWD 2005 Express
try to complete uninstall .net framework and install it again or get the latest copy of .net framework to install 3.5 latest version already available for download
Dec 01, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
