Question about Epson Printer
Dell 922 printer alignment problem after refilling cartridge
Will having my origional cartridge refilled cause alignment problem? Should I buy a new cartridge? Printer says remove protective tape but no tape on cartridge. I have tried normal alignment steps to fix as suggested by dirlinda89 yesterday. Can you help?
    Sniper:
  • 54 Answers
Sounds like the cartridge ink jets have dried up. Try running a cleaning on them to see if you can unclog them. If this fails to work try gently rubbing the ink jets with a Qtip and alcohol. If this doesn't work for you then you will need to purchase new cartridges.
Posted on Feb 02, 2009
HOW TO RE SET INK LEVELS
Dell Series 5 ink cartridges have a sensor in them and cannot be refilled. Article on refilling Dell ink cartridges
They can be purchased at Staples, Walmart or Dell's website.
Rick
May 14, 2011 | Dell 922 All-In-One InkJet Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
Poor print quality after several cleanings and alignment tests. prints the alignment page fine and when I print a regular word doc. the text is misaligned
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 17, 2010 | Dell 922 All-In-One InkJet Printer
I had my empty color ink cartridge m4646 refilled.when i install it it keeps showing empty.the printeris a dell all in one 922
bought a new cartridge &installed it. its fine now. my ink filler suplier said that they called dell & were told the cartridge was programed noy to be refilled.
Sep 04, 2008 | Office Equipment & Supplies
Refilled my Dell Ink Cartridge
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
Aug 09, 2008 | Dell 922 All-In-One InkJet Printer
Black ink cartridge
It seems that its an hardware issue with the printer as you have already replaced the cartridge with a new one.
If the printer is in warranty contact DELL to get the printer replaced.
I would also suggest you not to use refill cartridges. Always buy genuine cartridges. As using refilling cartridges spolis the printer.
It damaged the print heads in the printer.
May 30, 2008 | Dell 922 All-In-One InkJet Printer
My Hp does not recognize my color cartridge?
Sometimes the color bleeds over. Did you wipe down the contacts and clean the heads? Also, most of the cartridges have low ink sensors in the. Even if you have them refilled, they will still show as low ink. The only solution is to buy the new ones.... $$$$$$.
Dec 12, 2007 | Dell 922 All-In-One InkJet Printer
New cartridge problems
I read that the cartridges have sensors in them from Dell. When you buy a reman cartridge of refill them, the printer is still picking up the same level as when it was empty. The only way I know to resolve this is to pay $$$$ more for the Dell cartridges.
Yet another reason I will never buy Dell again.
Nov 21, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 printing problem
sounds like your ink mixed with other colors only fix replace with new cartridge
Nov 05, 2007 | Dell 922 All-In-One InkJet Printer
Epson Printer Logo
712 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
