Question about HP OfficeJet 6110 All-In-One InkJet Printer
Window says there is a scanner failure.
There is a rhythmical clicking sound from the right rear side of the machine and the window says there is a scanner failure. It advises to turn off then on, the power. This does not resolve the problem. I am unable to print or copy while the machine is in this state, Any ideas?
I recently had the same problem, and it is a very easy fix. What you have to do is remove the top and clean the underside of the glass. There is a white strip that lets the scanner know its in the home position. Pop off the control panel cover. Remove the 3 torque screws in the rear and the one on the right. VERY carefully release the buttons for the control panel with the tabs in front and slide out, careful there is a control ribbon underneath so be gentle. Then from the front there are tabs on each side to release the top. Clean glass and replace, should work good as new.
Posted on Feb 04, 2009
The pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Sep 17, 2013 | Epson Perfection V500 Flatbed Scanner
    2003 cadilac deville driver window off track. motor seems to work but window will not go up.
    Window regulator is bad in the drivers door . Do you know what a regulator is ? The Trainer 24 Power Window Troubleshooting Do you know anything about automotive electrical testing ? How to read an use a wiring diagram ? Do you know there are two side to a electrical circuit ? B+ voltage an a ground side . Plus there is electronic control modules and class 2 serial data network involved . When you push the switch for a window othen then drivers window on the drivers door . a class 2 message is sent to the other doors modules . The correct module will then open it's window .
    http://www.bbbind.com/free_tsb.html Check out free wiring diagram here .Enter vehicle info . year , make , model and engine size. Under system click on body & accessories , subsystem click power windows . Click search button , then click each link one at a time .
    Mar 27, 2017 | 2003 Cadillac Deville
    ERROR "NO SPEAKERS OR HEAEDPHONES
    Check the device manager for any sound driver issues to do this
    1. Click start -> right click on computer/My computer -> left click on properties
    2. Go to Device Manager
    If Windows XP
    2.1 System Properties window will appear -> Click on Hardware Tab
    2.2 Under Hardware Tab -> Click on Device Manager
    If Windows Vista or later versions
    2.1 Click on Device manager located on the upper left side of the Properties Window
    3. Under Device Manager try to check if there is Other Devices among the list
    4. If there is Multimedia Sound or any association with Sound
    5. If there is just reinstall the sound driver using the disk that was given to you by the computer manufacturer.
    6. usually the disk is the mainboard disk that came with the computer
    May 19, 2011 | Computers & Internet
    I lost my CD installer for audio driver and i was not able to find it anywhere in the web. please help. i am using. windows2003 OS. thanks
    Hi
    I would need to know what kind of sound card you have to get the drivers for it .
    Click the Start Button at the bottom left of your screen and then click the "Programs" folder.
    Next, click the "Accessories" "System Tools" and then the "System Information" folder or program (depending on what version of windows you have).
    Within the System Information window, click the + symbol next to Components.
    Click "Sound Device" (or "Multimedia" and then "Sound Device") and in the right-side of the window you should be able to locate complete information about the sound card.
    If you could put that information on here I will try to locate some drivers for it.
    Hope this helped
    Alistair
    Jan 11, 2011 | Computers & Internet
    From drivers side hear clicking for rear right side passager window won't work on Jeep 04 limited
    clicking sound from the window tells me that your window is out of its track
    you'll need to remove the door skin to diagnose and repair
    Apr 02, 2010 | 2004 Jeep Grand Cherokee
    2004 honda odyssey rear window passenger side won't open
    First check fuse #7 and #16 in the passenger side dash fuse box, however I've seen this happen allot on this body-style of Odyssey's. Here's a quick check you can perform: Operate the rear vent window switch and listen for a 'click' in the rear of the van next to the vent window. This is the relay 'clicking'. If you hear the relay 'Click' you now know that your getting power in the circuit. This means that the vent motor is faulty. This is a common failure and they usually go out in pairs, so the other side maybe on its way out too. If you don't hear the 'click' than you'll have pin test the multiplex control circuit for a fault.
    -hope this helps
    Feb 06, 2010 | 2006 Honda Odyssey
    Power window control
    So as not to be repetitive, for the failure of your power driver side window and rear window, review this handy diagnostic article, which identifies the possible causes, from a bad fuse, relay to window motor, etc.:
    http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Windshield_Windows_Window_Does_Not_Roll_Up_Down.htm
    This should help narrow down your particular cause.
    Brad
    Jun 06, 2009 | 1999 Lincoln Town Car
    When I turn the printer on, a rhythmic banging sound starts
    Is the scanner transport lock engaged?
    This is either a screw, pin, Clip, Slideswitch or button that keeps the delicate scanner head from moving during shipment.
    Look for it in the back and on bottom. If that isn't it, then the driver circuit for the stepping/space positioner motor is bad and you need a techie like me to fix... or just get a new AIO for $39.95 from Wal Mart.
    Mar 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    Ben Johnson
