Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Roller motor on a DC17 dyson wont turn on
I have a dyson dc17 animal- the beater bar motor got jammed and quit working- I cleaned all the hair and junk away from the belt, and drive area. The motor will now come on when the handle is lowered. Is there a fuse or a reset switch someplace that I can reset or replace, Or is the motor shot.
  • tlplesia Feb 07, 2009
    I have same problem
There is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
Posted on Aug 09, 2009
  • 1 more comment
  • Daylilydaze Sep 01, 2011
    There is a gray beater switch next to the red power switch. The gray switch has a picture of the beater bar and on/off on it. Just push down on the gray switch to reset the beater.
  • Denise Hammer Dec 27, 2011
    Thanks for the information on the reset button under the switch covers. The instructions worked perfectly. The only problem I had was when I pulled the switch covers off, they separated and this small white plastic piece and spring fell off. I wasn't looking down when it happened (reading the instructions here instead), so I had to figure out how to put the springs and white pieces fit on the two switch covers. So I'd add be very careful upon removal so you don't have to puzzle it out. I got lucky and got it all back together, and now my vacuum works again. (And no, simply pushing the brush bar button to "on" would not have worked since the switch was tripped).
  • Tom Danulevith Nov 01, 2015
    Thanks. Worked great.
    President:
  • 389 Answers
Well... not sure about this, but worth a shot. I did get one of these in for repair a while back, with exactly the same problem. The owner hadn't realized that there's an on/off switch for the brush motor. It's located on the front of the handle. Not sure, but it may be that this switch cuts off automatically if the motor gets overloaded, and needs to be reset manually.  Try it!
Posted on Feb 11, 2009
    There is a gray switch next to the red power switch. The gray switch has a picture of the beater and on/off on it. Just push the switch down.
Beater bar
It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Has anyone figured out what the silver cylinder is that can fall out when you're cleaning the beater bar?
I'm sorry to hear you're having difficulty with your DC17 Animal. If the idler has fallen out of your machine, I'd encourage you to get in touch with us directly, as we'd appreciate the opportunity to provide further assistance.
You can call our customer Helpline on 1-866-693-9766. Alternatively, if you email us at askdysonUS@dyson.com, someone will be in touch as soon as possible.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 30, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Beater Bar Won't Work. The beater bar starting to make a very loud grating sound then stopped working. I cleaned the entire area (there are no obstructions) and the belt is OK. The beater...
I'm sorry to hear that you're having difficulties with your DC17's brushbar. If it appears to have jammed completely, it's probably best if you get in touch with us directly so we can help - please call free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Oct 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson blueprint beater bar won't turn
The Dyson DC 17 has a rug / floor switch on the head of the vacuum. Please check to make sure the switch is in the Rug position. If the brush roller still does not turn then you have broken the belt and need the following part.
Dyson DC17 Geared Drive Belt, Genuine Dyson Part # 911710-01 - Free Shipping
Apr 08, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar is slipping on belt on my Dyson DC17 animal
Beater bar was turning intermittently. No noise. Removed bar, disassembled ends and removed lots of junk. Replaced, and works like new, so far.
Mar 26, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
Feb 26, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson animal is hard to push on carpet - the beater bar is still operational. When I turn off the beater bar and run the vacuum on hardwood the beater bar stops moving, but it still ''rolls'' on the...
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
Sep 20, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson animal
sounds like you may have alot of hair or thread wrapped around the bar, this can stop it if there is enough, have a look at the beater bar (brush)
Jun 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
4,658 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
