Microsoft Windows Vista Ultimate Edition Logo
Posted on Feb 02, 2009
I have vista 64 bit osis there any tc/c++ compiler that can run
I have vista 64 bit operating system.is there any version of turbo c/c++ that can run on it?please give mr details
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Feb 02, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
943
Points
14
You may try donloading Dosbox which is an Excellent program for running all 16bit and 32bit Programs
OR
you can checkout Dev++ which is a C++ compiler for all 64bit and 32bit Operating Systems as an option. Search it on Google and Download it may be better compiler for Vista than the traditional C++!! Rate if the answer helped!!
2answers
C++ not working in Windows7 64 bit
rty geeting the c++ supprted for windows 64 bit,,,,,u can get it in esnips.com
5helpful
How can i install turbo c in windows 7 x64
How to install Turbo C++ on Windows 7 We are providing detailed procedure how to install Turbo C++ on Windows 7. The very same procedure can be used on Win Vista. If you are running 64 bit version of Win 7, read this article. Users having Win 7 Pro and Win 7 Ultimate should use the virtual Windows XP Mode to install Turbo C++.
Installing Turbo C++ on Windows 7
1. Extract the zip files to: e.g. C:\TurboC
step1.jpg Extract zip files
2. Run the install: C:\TurboC\INSTALL.EXE
step2.jpg Run the install
3. Press Enter to continue
step3.jpg Press Enter to continue
4. Enter the Source drive: e.g.C and press Enter to continue
step4.jpg Enter the Source drive
5. Enter the Source path: \TURBOC and press Enter to continue
step5.jpg Enter the Source path
6. In directories specify where Turbo C files are copied. E.g. C:\TC . When done go to start instalation and press Enter
step6.jpg Specify where Turbo C++ files are copied
7. Succesfull instalation
step7.jpg Succesfull instalation
8. First launch from your destination e.g. C:\TC\BIN\TC.EXE
step8.jpg First launch from your destination
2helpful
2answers
HOW TO RUN TURBO C IN 64 BIT WINDOWS 7
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
3helpful
3answers
Why turbo c does not work in windows 7 64 bit
You're a programmer you should know this. Turbo C is a 16 bit application. 64 bit operating systems cannot run 16 bit applications. You need to get the 32 bit version of Turbo C or upgrade to a newer compiler.
http://www.fileguru.com/apps/turbo_c_for_windows_7_32_bit
2answers
I m using vista home premium 64 bit opreting system & i am unable to run some of the softwares that run on 32 bit OS like TURBO c/c++ compiler. every time i try to run it it shows the message "the...
There are compatability issues with many of the 32 bit software titles. The 64 bit version of Vista is not backwards compatable with all titles of 32 bit Vista. You will have to down load the patch or 64 bit version of the titles you are having trouble with. You can try to run it in compatability mode but things like Turbo C/C++ will not function in that mode correctly. They won't debug right.
33helpful
6answers
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
3answers
Plz tell me how i can run c++ in full screen in vista ultimate
Hello
Use the command prompt. Maximize the window size. Change directory to c:. You will have a line that fits 75 characters and a window that occupies about 2/3 of the whole window. That's enough fore all reasonable problems. If you are not happy with what you get, you may try developping your C++ program under Linux.
Hope it helps
13helpful
11answers
Looking for a vista compatible c/c++ compiler
As 32 bit vista does not support full screen 16 bit plarforms(like c/c++) nd not at all suportable by 64 bit vista. to install u have to install the display drivers of XP, that can be found at the site of the manufacturer of ur Laptop/PC(in some cases graphics card manufacturer). All the best...., further having any query , pLz fell free 2 ask
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
