Newly installed g inverter GA25VA not starting up ? Help
Was working fine........now wont power up, not used for a month. My wife has a fitness class in the morning in the said room HELP
  • 400 Answers
Check that you have power reaching the unit, you may have tripped out on the main distribution board of the house.
Posted on Mar 05, 2009
Unit will heat only will not cool and how to repair
we have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
May 17, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a cherokee 1000 watt inverter.when i try to use my 700 watt microwave,the inverter just shuts down.but any other device i use such as a tv or dvd player works fine.what should I check?
I think you are probably not going to have enough start up power for a microwave.They draw alot of amps on start up and I think your tv or dvd will pull about 1/3 to start.
I have a 8750 watt max watt generator and my wifes microwave is the only appliance in the house other than dryer that will make it change rpms.
Hope this helps you. Thanks
Dec 29, 2010 | Inverter Electronics - Others
My inverter started flashing its green light now it wont turn on, i have checked the internal fuse's they are good, next i checked the fuse's in my car and they are good, i even tryed plugung in another...
This inverter is a good Walmart inverter.
I had one that worked for about 6 months.
There really is no affordable fix.
RECOMENDATION:
Take it back if you can as soon as you can, dont fix it..
Hope this Tip Helps.
r/
David
Jan 09, 2010 | Black & Decker Power Inverter PI400AB
Want To Install a 1250 W Power Inverter on a Class A Motorhome
You are definitely on the right track. When you choose your power inverter consider the following: buy the inverter for around 40% more of your anticiapted load. You will need a double pole transfer switch to isolate the inverter from the generator(and visa versa). A simple double throw double pole switch with fuse or breaker protection should do it. You wouldn't necessarily have to isolate the curbside circuit as the double pole double throw switch would simply be switching the power from the existing generator to your new inverter for only the roadside circuit; i.e. you don't need to worry about the curbside power source as it will always be connected to the other branch circuit. Even if your generator or other source came on the system would be protected no matter what the the roadside configuration was set to as only one source of the 2 roadside power sources would be connected at any give time to the roadside circuit. The six dots represent the connecions for the double pole, double throw switch; shown supplying the new inverter to the roadside circuit while the source from the existing generator or inverter is disconnected via this switch from the roadside circuit:
existing * *------* new power inverter; switched to source
Middle 2 dots represent your roadside circuit and represent the "throw arm" of the switch. Safe and simple! If you don't have a voltage meter for your batteries you can purchase one for a few bucks. Just run it across the terminals so you will know battery condition as it is being drained (you may already have this indicator) You can find a transfer switch at an electrical supply place, maybe even Lowes. Make sure you get the switch that will be in a protected enclosre. The enclosurre can be purchased seperately if you can't find the switch/enclosure package together.
Good luck....gary
Mar 12, 2009 | Inverter Aims Pure Sine Wave Power...
Hp laptop 9720us screen wont brighten or dim. last week my screen went blank brought it to a shop they changed the inverter and also some cable connection . works fine just not quite as bright as before ....
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Mar 10, 2009 | HP Pavilion DV9720US Notebook
Can't get power to my RoadPro 1500 DC to AC Power Inverter
I have had this same problem with several power inverters over time. The problem is usually one of three things.
Those starting with the simplest.
1. Too much current being drawn on the inverter.
Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
Solution (Replace the fuses)
3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
Hope that helps.
Jan 20, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
Faulty backlight hp laptop
Well, first off, do you get a screen (external or onboard) if you boot into the bios? If you have no video whatsoever, the only thing that would start working again after time off, then stop, would be the video module went. slowly, but it went.
Main cause is overheating, caused by the heatsink/fan becoming clogged up.
What makes you think the backlight was the problem BTW? Sure it wasn't just the inverter?
Let me know if you can access bios?
Good luck
Oct 20, 2007 | HP Pavilion dv1000 Notebook
Tower wont turn on
Your power supply inside the CPU has finally failed. I agree with Smooth_Gecko, to be on the safe side, borrow one and test it first.
Apr 19, 2007 | HP Pavilion a330n (Refurbished)...
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
