2002 Yamaha WR 426 F Logo
Randy Roa Posted on Feb 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Overheating runs hot after about 30 mins and it has cooliant
patrick dierckx
Level 2:
Sergeant:
  • Expert 310 Answers
  • Posted on Feb 04, 2013
 patrick dierckx
Expert
Level 2:
Sergeant:
Answers
310
Questions
Helped
82839
Points
766
Are all the tubes hot,if not then thermostat dont go open.
if all are hot see for thermocontact doesn work.
2000 VW beetle GLS 2.0L , radiator fans not working, no light on dashboard, all hoses hot- upper-lower. Changed fan sensor lower rad and temperature sensor, bye pass fan sensor with a wire #1 to #2 fan on...
The fan or fans that cool the engine are not turned on until the engine coolant reaches about 225-230F, so they may not run for a long time, if it is not overheating why are you concerned.
2answers
Mower blades will not engage when hot
overheating safetybsprings are wore out. they either got over heated or reached their limits
2answers
I Have a 2002 lincoln ls v6 that is overheating i've change valve cover gaskets,water pump,ignition coils,ts tat ,i let it run for about30 min with the heater on it took awhile for the heater to get warm...
you have wasted money on fixing what has not consequence on the oproblem
overheating is from 4 things
1--- no/insufficient water in the cooling system--air lock in system- fill radiator to cap level and bleed air out
2--blocked radiator cores -- have a radiator shop do a flow test
3-- fan not working--no power from relay, ECM. coolant temp sensor , fuses-- have an auto electrician check the circuit
4--- blown head gasket /cracked head-- have a compression test done
1helpful
My tv video and audio cut out after 30-60 mins of watching or playing my xbox. instead of the regular green power light i get a flashing yellow light. if i unplug the tv for 30 mins or so it powers back on...
Is the back of the T.V. unusually warm/hot? If it is your T.V. may be overheating. If it's not in an open area, move it to an open area to allow more air flow. If it is try directing a fan at it. If one of those helps then your T.V. might be overheating and you may need to replace the cooling fan in it.
I have a 1990 dodge dakota 2.5 standard. The belt
bad water pump or air in system??? look for bleeder screws
Stalls when hot
it is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
Cooling fans stay running even if engine cold
cooliant sensor is bad ,you have two,one for cooliant temp and one for cooling fan both are in therostate housing or in some of the cooliant ports,
My car goes through so much cooliant
How many times has it got hot? You better do a cooling system pressure test. Sounds to me you got more problems than a cloged radiator. Do you see a puddle under the car? Its got to be going someware. Do the test.
COOLIANT
The use in modern engines is not recommended because of the high temperatures encountered by the coolant. Etylene glycol or other antifreeze products also raise the boiling point of the water, to better avoid overheating. you will get it in professional garage shops or car repair shops but taske care you do not use water only object in plase of cooland if they suggest as it will damage the part.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
