Question about DFI CA64-TN Motherboard
Hi. I need to change the jumpers on the mother board type CA64B in order to enter the bios , after losing the administaro's password. Can you help ?
  • 152 Answers
Remove your motherboard cell (C2032) wait for 5 minute after that power on and you can see that
your bios get factory defult setting
Posted on Feb 02, 2009
I have a dell 3000 dimension desk top computer. The message I get after tapping the F12 key is as follows. Key board failure. Type password and press enter to leave password security enabled next line
The motherboard BIOS is activated when you press the F12 Key and can be locked via a password that is different from your pc user account. There is only one way to reset this because the BIOS is a chip on the motherboard. You have to reset the password using a jumper on the motherboard that is marked with PSWD. This will also clear the CMOS which is Computer Memory on Startup which tells the computer the different changes from the original bios chip. so you may have to go in and set some settings in the bios to have everything back to operational.
Turn off and unplug the tower before opening it.
The password jumper's location on a Dell Dimension motherboard can be found by reviewing the Dimension User Guides.
For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Now replace the panel and plug unit back in. You should be able to enter the bios without a password.
Oct 01, 2014 | Computers & Internet
I can't find the jumper on my dell inspiron b130
Hi,what type of jumpers do you mean? if you want to clear your bios you can use jumpers calls "CLR-MOS" or "CL-ms" or "cms_clr" that it means CLEAR CMOS or CLEAR MOS (stands for mosfet transistors built in mother board eeprom" you can clear it this way:
shutdown the pc or laptop find the jumper pull the backup battery up use a screw driver or an iron pin to short the jumpers together(if you dont find the jumpers after pulling up the battery short the battery+- together) wait 10 sec and then pull in the battery after that you have to go to your bios setting and set some data if you dont you may see errors like this in your screen before windows start up:
"DMI POOL DATA CHANGED" PRESS F1 TO continue" or something like that;
and if you dont know the bios setting ask from experts to do it for you because this setting is too dangerous and may harm your hardware,if you dont know dont touch it,
and one more thing:
if you mean another jumpers?dont touch it because some mother boards use jumpers for their settings or you may harm your hardware
kind regards
Apr 18, 2013 | Computers & Internet
Security password Removing
Hi, To remove Bios security password login in Bios then go to the security tab and remove the password. Or the mother board jumper reseting can remove the password of the Bios without Bios login.
Oct 17, 2011 | Dell OptiPlex 360 Desktop Computer
I have a pentium 4 mother board when i start it it demands for password to enter the set up and when i press enter it goes to the set up but i cant validate any changes because some features have been...
You probably need to clear the BIOS password. If you can find the correct jumper, you can do it that way. If not, unplug the computer, then carefully remove the battery from the mother board and leave it off for a half hour or so to make sure all capacitors have dissipated. Replace the battery and you should be good to go.
Aug 05, 2009 | IBM (25P3294) Motherboard
Need help forgot password for HP Compaq NX7330
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Please rate me .
Thanks .
Jul 29, 2009 | HP Compaq nc6320 Notebook
D520 setup locked, cannot change boot order or re-install os
Jul 24, 2009 | Dell Latitude D510 Notebook
Forgot bios password
does your laptop have a 25 pin serial port?
Jun 27, 2009 | Toshiba (P000191710) for T4850 Sound Card
Can' get back on computer
Hi. Is it the bios password or Windows password? If it's the bios jumper 1 on the mother board is the bios reset. Just reset the jumper and all shoul be good. If its windows it may be an administrator password you had when you set up your pc that being the case, depending on how you setup windows you may be able to press ctrl,alt, delete to get to user menu and press enter, alternativly clear the box and press enter.
Mar 31, 2009 | Computers & Internet
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
A friend install my mother computer. how to jumper
Set the jumper to recovery or to clear
CMOS Jumper
1-2 - Mostly normal
2-3 - Clear
0-0-0 Recovery no jumper
Its a basic conscept it can change according to your bios manual you follow - Trace the cmos jumper exactly dont short any other jumper
Jul 25, 2008 | EliteGroup Computers & Internet
DFI CA64-TN Motherboard Logo
125 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Matthew Spark
Matthew Spark
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
