Question about LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium
Connecting the fridge to the water point
Do you connect the fridge to the water mains - like a washing machine or to a separate portable water source?
  • 410 Answers
You need to connect your fridge to a constant water supply such as a water main make sure it is a cold water line that you connect to. good luck peyton
Posted on Feb 02, 2009
When water is on mains the hot water doesn't work only the cold working
If you have hot or warm wash selected and you get no hot water, a possible cause is that the solenoid inlet valve on the hot connection has failed. Try connecting the hot tap to the cold inlet on the back of the machine, and selecting cold wash. If you then get hot water coming in you will know it is almost certainly the solenoid inlet valve on the hot connection.
Nov 16, 2015 | Washing Machines
Water supply running extremly slow almost drop for drop what can the problem be. All connections are correct water outlet fine.
The pipe connecting the water supply from outlet to the machine could be blocked. Please remove the pipe and check it with another source. If choked with replace it.
Jun 16, 2010 | Washing Machines
No hot water coming into washer
Make sure the hot water valve is open. Check both ends of the connecting hose to see if there are clogged filter screens. If those are OK then the solenoid valve for the hot water has failed. Even though they operate separately, the cold and hot solenoids are usually in the same unit so the entire part that the hoses connect to will have to be replaced.
Dec 15, 2009 | Maytag Washing Machines
Cold water will not go into machine the warm water is just fine
Make sure the cold water valve is open. Check both ends of the connecting hose to see if there are clogged filter screens. If those are OK then the solenoid valve for the cold water has failed. Even though they operate separately, the cold and hot solenoids are usually in the same unit so the entire part that the hoses connect to will have to be replaced.
Dec 03, 2009 | GE Washing Machines
Msd2756geb water tube coming out door not hooked up?
Check diameter of pipe. Suspect its quarter inch. You will then probably need to purchase e.g. from ebay etc a 1/4'' to 3/4'' adapter which will allow you to connect your fridge pipe to a typical water pipe connector (i.e. similar connecting a washing machine), assuming you already have an available water conenction in the lcoation of the fridge!
Jun 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
My washing machine does not run at all
Plug off the wall mains. Drain out water. Check out the pump for anything clogging the impeller. Check wires connecting this too.
Mar 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
GEfront loader no agiate or spin just pump motor
Hi there, you may have a locked up gear case or drive shaft and clutch issues as well. i would check these points. also, check the motor connection for lose or separated connection. Here's another tip. there may be a pin coupler on the control panel that is not connected or lose. i would run a break point test on the control panel board as a last result.
please rate and god bless.
Mar 17, 2009 | Washing Machines
Connecting to water supply
If you mean icemaker or water supply it's easy you just have to connect a water pipe 1/4 to your main water supply of your sink 1/2 inch. Just putting a valve first on the 1/2 pipe reducing to 1/4 & you bring it to your water valve solenoid of the fridge. That's it!
Francois
Dec 10, 2008 | Freezers
LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium Logo
487 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
