Question about Bburago Citroen C6 Diecast Model
Citoen c3 heater blower on constant
Citroen c3 1400 hdi
blower for heater is on constant could this be the resistor
Check this out - it may be similar
www.johnandchris.screaming.net/berlingo_blower/berlingo_blower.htm
Posted on May 19, 2009
I would like to see and study this diagram of citroen c3 resistor unit radiator fan
You just to take it apart and test it. That's what I do on radiator and blower resistors.
Nov 10, 2015 | Citroen Cars & Trucks
What does anti pollution fault on Citroen c3 2007 mean
Hope this helps. http://citroenc3owners.com/diesel-c3-tips/citroen-fap-dpf-regeneration-antipollution-fault-c3-hdi-t215.html
Mar 04, 2015 | Citroen Cars & Trucks
How do i bleed the fuel system on a citroen c3 hdi 1400
bubble on the fuel line from the tank in the engine bay looks like a small rugby ball their should be a see through pipe on one side of it. squeese the bubble a few times watching for air in the pipe.
Sep 17, 2014 | 2006 Citroen C3 1.4i
Where is the blower motor resistor for citroen c3
this is not a easy task ,,turn on key on on the heater control panel push in the recurclator button look under the driver side above the clutch pedle a hole in the heater unit will have open up ,,you may need a torch to see this there is the resister unit turn it clock wise pull it down not too hard and unplug it replace with new one
Mar 01, 2013 | Citroen Xsara Cars & Trucks
Picasso heater blower not working
Hi all. Yes this is a very common issue. 2 distinct issues in fact are common with the aircon.
1 you get fan on certain settings only. This is the resistor gone and johnjohn2 has identified the fix for this above. This is usually (although not always not intermittent and so you will usually lose all other settings over night and they don't come back
2 you get no fan activity at all. This starts to happen intermittently and then gets more frequent until the fans won't work at all. The fix for this is expensive through Citroen but cheap if you get the part off ebay. It is the ignition switch cable which has a fault. A very common issue. You need to remove the ignition switch and replace the cable from it. Work is not long but plugs can be tight and fiddly.
here is the link for the part
http://www.ebay.co.uk/itm/Ignition-Switch-Cables-Wires-PEUGEOT-206-CITROEN-XSARA-PICASSO-Lock-Barrel-Plug-/121038091531?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c2e6eb50b
good luck
Oct 18, 2012 | 2001 Citroen Xsara Picasso
Remove heater control switch
Before removing the heater switch on this 2006 citroen hdi I would first have the blower motor checked and the most common reason for this and other blower problems would be the blower resistor.
Your blower works on and off at times, first locate the blower motor and the resistor. the blower motor is located on the heater box, look under the pass/side of the dash, you may have to remove under dash cover to see blower.
When you have located the blower now look to the side on the heater box, there you will see a connector plug, it plugs into a connection on the heater box, this will be the resistor, the resistor slides into heater box and the end of it bolts to box to hold it in place and then the connector plugs into it, if you can not locate it then follow wires that plug into blower , follow wires back they will lead you to resistor,
next time blower does not work wiggle connector to resistor and see if blower turns on, if it does then resistor is the problem. also unplug resistor plug at resistor and check for any burning of connectors at plug and inside resistor.
I would bet its a bad resistor or the plug is brunt due to high draw from bad connections, if plug has burn damage to connectors then replace the plug along with resistor.
Jul 08, 2012 | 2006 Citroen C5 HDi
Blower is on constantly
May not be the heater. Could be you have something burning up and this is causing the heat to be dispersed in to car.
If the pulleys all work on one looped belt, see if one of the pulleys is locked up (not spinning). This will cause the belt to burn and may cause engine to overheat.
What type car?
Sep 18, 2009 | Bburago Citroen C6 Diecast Model
Bburago Citroen C6 Diecast Model Logo
1,179 people viewed this question
Top Bburago Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Bburago Toy Expert? Answer questions, earn points and help others
