seethis causes and fix it. God bless you User Control and Display Board
If the washer won't start, the user control
and display board may be defective. Check for power to the washer first.
Timer
If the washer won't start the timer might be
defective. This part is often misdiagnosed, check other components
before replacing this time
Line Fuse
If the washer won't start the line fuse might have blown. Thermal Fuse
If the washer won't start the thermal fuse
may have blown. It can be tested for continuity. Watch our fuse testing
video for more information.
Line Fuse and Holder
have blown, or the line fuse holder might be damaged and need to be
replaced. Main Control Board
If the washer won't start the main control
board might be defective. This is not common. Check other parts and
causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if
there is power at the electrical outlet which the washer is plugged
into. Plug a lamp or radio into the outlet to check it. If the outlet is
dead, check the circuit breakers or fuses for the hom
Power Cord
If the washer won't start, check to be sure
there is power to the electrical outlet for the home. If that is OK, the
power cord itself might be defective. This is rare. You can check the
power cord with an Ohm meter for continuity.
a flash drive is used mainly for storing of files, you need a device that will play the files you want, in this case a device that plays mp3s and either transfer your music to/through it. Unless your transmitter states that it plays different media formats that is but i have never heard of that before. hope this helps.
wma files won't be read, only mp3 files, in my experience. My 512 mb SD card works, but it won't read my 8 gb SDHC card. I suspect it can't manage SDHC (high capacity) cards. I haven't tested yet, because as it turns out, neither can my computer... I think I'll fall back to a flash drive.
you will just need to de activate the FM transmitter to do that press the volume button at the bottom right hand corner of the main menu and uncheck the box that says something about the FM transmitter
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
