Question about Carrier Siesta II TCA101D Air Conditioner
Backing for my air con
I am not sure but picture is the same as the one i have i am trying to fing the back cover to go over the motor. Do you know where i can get one what materials to use to cove the back with tahnks Toni
  • 56 Answers
Yopu can try googling the manufacture and contact them..sorry that the best I can do for you with out seeing it for myself.
Posted on Feb 12, 2009
I replaced the T-con board on my Vizio TV, but I still don't have any picture, just sound. What else could it be?
Think something may have gotten unhooked when you put everything bacK together? Check out all connections and ribbons between boards for proper contact.
Jun 22, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Sanyo tv troubleshooting
this is a bad t-con board or a loose lvds cable from the t-con to the panel.try reseating the cable to the t-con and the tv panel,this means removing the back cover.
Dec 09, 2013 | Televison & Video
Phillips 42FPL7662D/05. I do not know why the tv has stopped displaying a picture. The power supply is okay. I have taken the back off, there does not seem to be any problems with any soldering. If you...
if still the sound is working but with out any picture the cause would be a screen back light failure or malfunction in the t-con board. if the totally black screen it was a failure in the back light, you will need to remove the back cover to access this part. it was located at the upper and lower portion of the panel display covered with metal shield.now if the display is only a white screen you can see it in dark room, then the cause will be a failure in the t-con board. the t-con board was mounted underneath covered with metal shield.before you come up with trouble shooting the t-con board tried first with re seat the connectors which have loose contact.hope this can help good luck.
Nov 17, 2012 | Televison & Video
The picture is starting to go out - when you turn it on the screen is totally white, then about an hour later, the picture begins to appear, will go out, then returns but it takes quite a while before the...
I think that there is only a loosed or cold solder in the t-con board or some bulge up or leaky capacitor in the power supply. Try to remove the back cover of your unit then observe carefully if there is a bad capacitor in the power supply, if you see this bulge up or leaky capacitor try to replace it but be sure to observe the polarity, because this bad capacitor will cause your unit to malfunction this bad capacitor is producing a low and unfiltered dc output voltage. Be sure to unplug the unit before removing the back cover. Feel free to send feed back good day and best regards.
Aug 17, 2011 | Element Televison & Video
GOT SOUND BUT NO PICTURE ANY TIPS PLEASE INVERTER NOT FAULTY
Good day!!!
That problem is usually cause of bad inverter board or T-con board....
Please do this procedure to determine the problem:
  1. Open the back cover.
  2. Check the input voltage of inverter board.It should have 24vdc
  3. If you don't have 24vdc the problem is on the power supply...Check the possible open resistors that pass through the 24vdc line..
  4. If you have 24vdc and your TV is no back-light...The problem could be on the inverter board..Please replace it to fix your problem..
  5. If you have back-light but no picture on the screen the T-con board is faulty..T-con board is the responsible for processing of video comes from the main board..Please try to replace it if this symptoms appear..Have back-light but no picture or image on the screen.
I hope this solution will be helpful..
If you have any clarification or more query please feel free to ask..Just add a comment to post your query..
Thanks for consulting fixya..
Aug 13, 2011 | Televison & Video
Hear flapping sounds when i turn it on and when i opened it the coil looking thing looks like its a little icy i clean out the net looking thing from dust that accumulates on it but its still making...
Hi, you need to take out the whole air con and clean it, heres how to clean it, first open the case then wrap with plastic the power supply and the motor so that it cannot wet, then washed the whole area of the air con and dry it with high pressure air sprayer. then return back the cover and test it. hope this could be helpful. thanks
Apr 27, 2011 | Heating & Cooling
Samsung tv negative image
LVDS cable from the T-CON
This seems like a problem with the T-CON board or it's connections. This is the low cost method to try.
If this set is under warranty you should return it to get it repaired/replaced by the seller. If not then;
This sounds like the T-CON board or the LVDS cable connection is bad. Turning on and off the set will cause the connection to heat and cool and not make good contact.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacing ) or have a friend with knowledge/skill you can fix it.
>Unplug the set and disconnect any cables.
>Lay on a flat surface covered with a cloth.
>Remove the back cover.
>The board is located near the middle of the set underneath metal shielding.
> Re-seat the cable by disconnecting and re-connecting the flat cable(s) connected to this board. See if the picture corrects.
You can try this several times.
If this does not correct the problem you may have to replace the T-CON board.
>Replace the shield and back cover.
You can search for replacement boards from places like shopjimmy.com, ebay and other sites.
The board will look something like this;
Mar 30, 2011 | Samsung Televison & Video
I have a blank line running vertical down my screen about 5" wide it is over the main menu I tried other inputs resetting. what is the problem and can it be fixed
This sounds like a problem with the T-CON board. This is the LCD controller board for displaying images on the screen.
Some times the contacts on the connectors do not make good contacts for whatever reason.
IF you know how to work on electronics or have a friend with knowledge/skill you may be able to fix it.
>UNPLUG the set and all attached cables.
>Lay the set face down on a cloth covered surface.
> Remove the shield over the T-CON board.
> Disconnect AND reconnect the cables to the T-CON board. Be careful here. The connectors will have a clip which must be released to remove the cable. Hopefully this will clean the contacts.
If it's not fixed, try it again.
If the problem is not solved you can try replacing the T-CON board. Make sure the part numbers are the same.
YOU CAN TEST THE SET BEFORE THE BACK COVER IS RE-INSTALLED BUT BE CAREFUL. IT'S ELECTRIC !!
>Replace the shield over the T-CON board.
>Replace the back cover.
>Try the set.
You can search for T-CON board from;
www.shopjimmy.com
eBay
http://www.tvpartsandmanuals.com/
http://magictvparts.com/
etc
The board will look something like;
Feb 17, 2011 | Samsung LN52A550 LCD TV
I have an vizio 32"
This looks like the cables connected to the T-CON board may have worked loose.
The T-CON or timing controller, is what sends the video signal to the LCD (sometimes called LCD controller). The cable connectors on this board have very small contacts. Sometime some of them can become loose because of heat, contamination, shaking etc.
IF you know how to work on electronics or have a friend with knowledge/skill you can repair it.
DO THIS ONLY IF YOU KNOW HOW TO WORK ON ELECTRONICS.
> Disconnect all cables/cords on the back of the set.
>Lay the set face down on cloth covered flat surface.
>Remove the back of the set.
>Remove the metal shield covering the T-CON board. This board generally located in the center near the top.
>You can wiggle the T-CON cables around (for better contacts) to try and get the streaks to go away.
> Set tv upright so it is stable.
> Reconnect the signal source and power cord. DO NOT TOUCH ANYTHING ON BACK OF SET!
IT IS ELECTRIC !
> Use the remote to turn on the set. IF the streaks are gone, then turn set off
and UNPLUG THE SET and remove the input signal cable.
Resume operation.
IF moving the cable does not improve the signal you can disconnect/reconnect the cables and see what the picture looks like. Be careful not to damage the connectors. They may have clip that must be released first before removing.
IF disconnect/reconnect the cables does not work you can purchase another T-CON board and install it. The boards are relatively inexpensive.
I think the board will look something like this;
!bw!llnwcwk~$(kgrhqn,!icev1+0f2hlbmg89w0)sq~~_1.jpg?set_id=880000500f
Feb 16, 2011 | Vizio L32 32 in. LCD HDTV
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
Carrier Siesta II TCA101D Air Conditioner Logo
98 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
