Question about Intel Motherboard
WHAT ARE THE COMPONENTS OF K9MM-V AND WHY IS IT IMPORTANT... IDENTIFY THE LABELS AND LABEL IT...
  • Thomas F. Schneider May 11, 2010
    You can look it up at the link below here but you will need to know the CPU socket number or go through every number looking for you model motherboard.
      Download a manual and it wil have an illistration showing allthe major parts. CPU socker, Graphics socket,Ram sockets,BIOS ,Video,etc
    http://www.msicomputer.com/support/msi_s...
    President:
  • 2,692 Answers
Here is the link to you product model support page:
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1∏_no=1104
Posted on Feb 22, 2009
How do I import addresses from excel to my Dymo LabelWriter 4XL Thermal Label Printer?
You first need to install DYMO Label. If you already have installed it, click Address Book > Import to import addresses.
^CM
Sep 05, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Where is the fuse box on a 2004 jeep liberty
Your 2004 Libery has 2 fuse centers
1. Interior Fuses
The passenger fuse panel is on the left side of the instrument panel.
A label is attached to the fuse panel cover to identify each
fuse for ease of replacement.
2. Underhood Fuses (Power Distribution Center)
Your vehicle is equipped with an electrical power distribution
center located in the engine compartment near the
battery. This power center houses plug-in "Cartridge"
fuses which replace in-line fusible links. The power
center also contains "Mini" fuses and plug-in full and
micro ISO relays. A label inside the latching cover of the
center identifies each component for ease of replacement,
if necessary. "Cartridge" fuses and relays can be obtained
from your authorized dealer.
Oct 31, 2011 | 2004 Jeep Liberty
Where is the serial number on my pavilion g7 laptop
Hi.
Good day. The product and model numbers that identify the components in your notebook are printed on a Service Tag Label . This type of label has been affixed to the bottom of the notebook or under the notebook battery since the year 2000. The following sample shows you how to identify the information on the label. Hope this information helped in answering your questions. Have a great day
May 25, 2011 | HP Pavilion dv9000z Notebook
Wiring a coil, need to know which wires go on positive side and which wires go on negatve side
I can't give you specifics here, as your info is a little scarce.
Generally, on welding transformers, they are converting standard outlet power to very low voltage - but at very high amperage.
This being the case, the output windings will have much thicker wires than the input.
- So - thicker wires out to welding rectifier plate.
The rectifier will take care of the AC, and convert it, so polarity is not important.
Input will be AC as well, so this doesn't matter either.
Just make sure you identify the windings as pairs - and stick labels on them before fitting.
I use paper labels attatched as flags - then tear them off when finished.
The people supplying the coil should be able to identify the outputs for you.
Mar 02, 2010 | Welding Tools
WHERE DO I FIND THE MODEL NUMBER ON MEDION TV
Tips for identifying Manufacturer:
When adding devices to your Harmony account, it is important to correctly identify your components so that your Harmony Remote can control them as efficiently as possible. Below are some tips to help with figuring out how to add your devices correctly:
Tips for identifying the Device Type for your devices:
A general category description:
Examples: Television, VCR, CD Player, DVD Player, Stereo Receiver, Amplifier, Game Console, etc.
1. Also referred to as “make” or “brand name”
2. Typically on the front of the component
3. Sometimes on the label with the Model Number
examples: Sony®, Phillips®, Denon®, DirecTV®, TiVo®, etc.
Tips for identifying Model Number:
Note: also “Model” or “M/N”
1. usually on a label on the front, back or bottom of the component
2. the model number may be different than model name
3. also found in the component’s user manual
4. Not the model number on the old remote control
5. Not the serial number (SN) which is usually much longer
examples: RC-QN3BK, CT-36XF36C, Explorer 3100, L32 HDTV 10A, etc.
Jan 25, 2010 | Televison & Video
I am plugging in a satellite receiver, which coax input do I use and what source setting? Thanks!
If your using HD, then use the RGB component input 1. or AV 1 if your not using HD.
Dec 18, 2009 | Protron PLTV-37 37 in. LCD Television
Sparks off part labeled gs 22
If you can post a pic of the component I can identify it for you and list where to get the part at.
Oct 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Soldering iron tips
It is very tempting to start soldering components onto the circuit board straight away, but please take time to identify all the parts first. You are much less likely to make a mistake if you do this! 1. Components stuck onto paper Stick all the components onto a sheet of paper using sticky tape. 2. Identify each component and write its name or value beside it. 3. Add the code (R1, R2, C1 etc.) if necessary. Many projects from books and magazines label the components with codes (R1, R2, C1, D1 etc.) and you should use the project's parts list to find these codes if they are given. 4. Resistor values can be found using the resistor colour code which is explained on our Resistors page. You can print out and make your own Resistor Colour Code Calculator to help you. 5. Capacitor values can be difficult to find because there are many types with different labelling systems! The various systems are explained on our Capacitors page.
Aug 27, 2008 | Cooper Industries Mcm Tool P2C Cordless
Labels print out of center
the important thing is if you are using different type labels and sizes before printing see to it that the labels must properly calibrated..to avoid printing incorrectly
Jun 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Intel Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
