Question about Food Mixers
My Super Grinder needs repairs
Super Grinder HL 1641/D is not working as the grinder was stuck and when I ran the mixer the small wings snapped
  • Anonymous Mar 30, 2014
    Need to replace one of the wacher? need help.
  • 27 Answers
The blade of the jar got jamed, you have to remove the jar shaft and lubricat with any oil and refix it back
Posted on Mar 06, 2009
  • SANJAY JIRANKALGI Jul 27, 2013
    sir, how i can remove it and fix it , please tell me detail.
Was using a spatula to push meat down into the grinder and it is now stuck how do I fix?
Either muscle it out or get to the motor from underneath and manually turn it in opposite direction to free up the item.
Aug 12, 2016 | Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Need help getting food grinder attachment troubleshooting cant get mine to operate
When you use an attachment the mixer will still stir. You need to remove the beater when using an attachment.
Mar 04, 2015 | KitchenAid K45SS Classic Stand Mixer
I have a kitchen aid 5 at. Mixer when I use my grinder attachment I notice oil/ grease on shaft what is that caused from
Sounds like a problem with the bushing around the accessory drive. If still under guarantee take it back and get it sorted. If out of guarantee take it to an authorised service centre.
Dec 15, 2014 | Food Mixers
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The attachment for grinding meat on the front wont work ? mixing arm in bowl works fine ! why wont it engage?
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
Grinder attachment
Cindy,if it has a screw take it out,grab a flathead screwdriver and work your way around the cap.Some mixers have been painted or just the gunk over the years make the cap hard to pull off.The push button i have never seen on a hobart mixer near the hub.Give me the serial and spec number.
Nov 12, 2008 | Hobart A200 Stand Mixer
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
Dry grinder
yes - dry well after wards
May 17, 2008 | Bamix De Luxe Hand Mixer
Food Mixers Logo
443 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
