Question about Microwave Ovens
I have a Philips Super Grinder HL 1641/D and fixed the Grinder jar. But as soon as I started the mixer ther was a loud sound and I found that the small projections on which the grinder sits had broken. I need to repair this
4 Suggested Answers
Smith-alone
  • 360 Answers
SOURCE: I have lost the grinder
Hi, The company handles these as Blendtec now. The web site is at http://www.blendtec.com/default.aspx Maybe this will help:
Customer service and sales are available from 8:00 am to 5:30 pm (MST) M-F.
Phone
Toll Free: 800-253-6383
Local: 801-222-0888
Fax: 801-805-8585
Posted on Jul 27, 2010
  • 47 Answers
SOURCE: I bought a milton juicer/mixer/grinder
By 'milton' do you mean that the mixer is of the 'Hamilton Beach' brand? If so, can you find a model number on the bottom of the product? With that, you could probably find a user manual online.
Posted on Feb 28, 2011
Sagar Tech
  • 107 Answers
SOURCE: grinder appears to be grinding,
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Posted on Sep 06, 2011
My mixer is working fine but makes a very loud screeching noise so i am afraid to use it.
Hi..mixer has motor on it.It is responsible of rotating the pan.but yuo said it does worked however yuo can just hear a noise..If yuo can remove the motor on it.check if the small shafting runs smoothly .its just some debris has have blocked the shafting that makes any sound.Or the motor itself does not have any lubrication to run it smoothly..the ROTOR that is the inner part of the motor that rotates might as well does not have anymore lubrication .its bearing .So it would be better to check it further..Hope this idea helps.
Jul 09, 2011 | Microwave Ovens
Kitchen Aid Mixer Model KSM5PSGR . I have had this mixer for about 15 years and recently while mixing dough, it started struggling to spin, and at some point stopped spinning. I just turned it on, and it...
it's possible the brushes on the motor are burned out. Are there 2 screw holes on the sides? You should have one on either side that look like a flathead screwdriver would fit in them? If so, inside those chambers are the brushes and springs for your motor. You can try replacing them. You should be able to order replacement brushes based on your model number(found on the bottom of your mixer). Let me know if that helps.
Jun 10, 2011 | Microwave Ovens
I bought a milton juicer/mixer/grinder product which is manufactured on 2000. Unfortunatly I lost the user manual and I couldn't operate properly. So can you help me in this regard,...
Feb 28, 2011 | Microwave Ovens
When I turn on the microwave there is a hum (model NN-S763
this could be loss windings on the mains coil or the capasitor is shorting out my gess is its soon going to pack up on you,,,start saving up your pennies for a new microwave as ther so cheap now its realy not worth having them fixed
Mar 09, 2010 | Panasonic NN-T583SF Microwave Oven
Microwave timer counts down super fast
try unplugging it for about 15 minutes. if that doesnt work, you might as well get a new one. i fix everything myself for just the cost of parts and i have found that what parts cost for a microwaves, its cheaper just to buy a new one.
Oct 17, 2009 | Sharp R-540DK Microwave Oven
JVM1440 BD - has a loud noise when I turn it on
Sounds like the "hub" for the turntable is worn. either that or the actual turntable motor. also insure the "plate" has a ring under it with wheels. sometimes I find those missing which in turn put far too much loud on the hub & motor, hence wearing them out pre-maturely.
you should be able to pull the hub out from inside the oven, if not. remove the filters below and if you twist just right you should see a small round device mounted with two tiny philips head screws, that's the turntable motor. It's usually the "hub" that wears though, so it's likely an easy fix. The most difficult part may be finding the new replacement part itself.
hope that helps,
good luck
Sep 26, 2009 | GE JVM1410 Microwave Oven
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
Jul 16, 2009 | Microwave Ovens
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
54 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
