Question about Compaq Armada 1700 Notebook
I got my system 's hard disc damged ( Compaq 1700 Armada series)
My sytem's hard disc has been devised to be damaged . ihave A Compaq laptop bearing model name 1700 Armada with 4GB HARD DISC Capasity .hough i have updated it wih 20GB.
AND ONE MORE PROBLEM WIH CDR it didn't shows anythi.
plz do the needful
send me sone solutions
  • ClamaKlem
    ClamaKlem May 11, 2010
    Let us know the code model, write some more details about your hard drive issue. About the CDR, maybe it has some dirt on the lens, or it is too old. Check twice. Lucas from Argentina
Compaq armada 1700-when powering the system the following error appears "Error loading operating ststem"
There is a good possibility that the hard disk drive may be failing, so if you can try running diagnostics and see if you get a failure on the hard drive.
If you can't run diagnostics, then boot to your Windows CD, press R for recovery console, then at the command prompt run the command CHKDSK /R see if you get any errors on files.
If that doesn't resolve, then boot to the windows CD press enter instead of R and repair windows.
If that still fails, then the hard drive is likely bad
Aug 20, 2011 | Compaq Armada 1700 Notebook
DRIVER VIDEO COMPAQ ARMADA 1700
there are so many models of armada 1700
please select your model from below link and then your operating system and it will show you all the drivers.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=96221&taskId=135
Mar 01, 2011 | Computers & Internet
Have a Compac Armada 1700 laptop with Windows NT4.0 After reinstallation of NT4.0 i have only 16 colors on screen. Sombody know how to get 256 colors? Karl Hole Norway
hi
you have not install the Display drivers just go to below link and download the VGA drivers
http://www.laptopdrivers.net/video-drivers-for-compaq-armada-1700/
vote me if you find your solution
Oct 13, 2010 | Compaq Armada 1700 Notebook
Hard drive
You will find the drive inside the small compartment on the botton toward the front of your computer.
Thank you for your interest in FixYa.com
Jun 24, 2010 | Compaq Armada 1700 Notebook
Hi i have compact armada 1700 and it is missing operating system what is the problem
Hi
If it is missing the operating system then you are missing windows i.e. Windows XP, Windows Vista etc etc
You will need to purchase a CD from any reputable PC shop or online, and then install onto your PC
Mar 08, 2010 | Compaq Armada 1700 Notebook
Cand get driive to turn the disc in the main boot
for you getting your CD DRIVE try to ask from a vendor that sells parts of system and Accessories near you with your make and model
Feb 22, 2010 | Compaq Armada 1700 Notebook
Help with compaq armada 1700
Sounds like your Hard Drive is gone, or you have a floppy disk in drive or cd in drive, could be a CMOS setting wrong also, but I would suspect the Hard drive is shot on a machine this old. P.S. I am running an Armada 1700 right now. Your HDD door should be on the bottom of the machine about 3"X3" with a 1"X3" lip that is hinged and has a catch on it, you need to release the catch and see if it even has a hard drive in the caddy, it will slide towards the front of the machine, slide it back towards the back it is only held in by the cover's foam and may have come dislodged. Some things to try.
Jul 14, 2008 | Compaq Armada 1700 Notebook
Please help me with my COMPAQ ARMADA 1700
plz check the hard disk cable if its ok then your hard disk may be bad.
Jun 11, 2008 | Compaq Armada 1700 Notebook
Hard drive controller problem
S.M.A.R.T (system monitoring)is the warning software that detects when a hard drive is about to fail, so i would back up any important docs to a disc or usb drive immediately and replace the hard drive. The hard drive controller itself will not be the problem, it's the controller saying that the problem is the drive, the controller is only a driver and not a peice of hardware, pressing F1 will ignore any faults and continue to boot, but especially if it doesnt always boot it's definately your hard drive.
Jul 26, 2007 | Compaq Armada 1700 Notebook
Compaq Armada 1700 Notebook Logo
105 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
