Question about LG KU990 Viewty
Can't connect using LG PC SUITE
I've installed the software which came on the disc and it worked fine the first few time. It does not work any longer. I've not upgraded my computer.
I use the Connection Wizard and it shows that the phone is connected. However when I try to backup or click on Contents the phone itself says "CANNOT EXECUTE CONFLICT WITH (SEARCH)". On my laptop and alert box says "FAIL TO CONNECT TO THE MOBILE HANDSET. PLEASE CHECK THE COM PORT AND CONNECT IN IDLE SCREEN. DUE TO MULTIFUNCTION, DESPITE IDLE SCREEN, IT CAN BE FAILED TO CONNECT."
Can you please tell me how to correct this?
  • 5 more comments
  • Anonymous Feb 02, 2009
    i have the same prob as you
  • smelly socks Feb 03, 2009
    same has happened to me,
    i even bought a new cable, but it will not connect,
    i cannot get my pics on the comp!
  • Anonymous Feb 06, 2009
    me too annoying really :L
  • Anonymous Feb 15, 2009
    it did work before, THEN i took pictures using the phone, and as i was going to transfer them onto my laptop, this happened. Pft, fail.
  • Jobby75 Feb 21, 2009
    Got the software from the net. Same problem. Sometimes I can but 99.6 times I cant. Please help.
    KB
  • terryally Mar 04, 2009
    You have to go to the start screen for the connection to work and secondly, if you have the self-lock feature enable you should either extend the length of time or remove it.
    Zanafix, solution should also work - just reboot the phone. That will take you to the start screen.
  • Anonymous Apr 06, 2009
    Have same problem, but i believe it has to be some kind of administration privileged after or before the installation of PC Suite... then it messes up with the installation, in some cases, they work for a short period of time, the others, not even the first time... so, ive solved it using a virtual machine, it meens the only way to work again is formating the pc...
Yep this worked for me . just switch off then back on. thanks zenafix
Posted on May 13, 2009
You can go into usb settings and change it to mass storage.. your computer will recognize it as a hdd.. from there you can drop files in any location..., also java games can be put in a folder and run from the handset
Posted on Aug 18, 2009
  • dsl1234 Nov 20, 2010
    This one worked for me - thanks! It simply downloads your photos to windows photo gallery page , bypassing the LG suite altogether .
Go back to the main menu of your phone and switch the handset on an off..this should work...because u will be in a search mode for something and you may not notice...this worked for my new LG 501
Posted on Mar 03, 2009
Go to C://Program Files/LG Electronics/LG PC Suite III/res
open PhoneInfo.txt file and add this line "KU990i=Sync,Contact,Contents,Message,Backup,Music,AAS,Java,ITK,VP,AutoRun"
under [Phone]
After open PC Suite and connect your LG mobile to PC!
Posted on Feb 20, 2010
Press middle button on your phone then press Running app tab then press "END ALL", retry connecting the phone
Posted on Jul 10, 2010
Hey, My problem is: Well I don't actually know how to install the LG PC suite for my computer. I have the phone LG KP 500 (LG Cookie) and I have tried many times to get it working, though I cannot....
Insert the disk. Do not connect the phone to the computer yet. Open My Computer and then double click the CD icon, the installation should begin, if not, double click Setup. Follow the on screen steps and only connect the phone to the PC when prompted.
Mar 07, 2011 | LG Cell Phones
Where can I download LG PC Suite ? No PC disc
Hai
You can use this software for LG KP 220 to connect the internet.
http://www.ziddu.com/download/8112974/PCsync.zip.html
from
hkmthumma
Oct 16, 2009 | LG KG800 Cellular Phone
LG PC Suite does not detect the LG KS360 phone!
You need to change the usb connection type on the LG. By default it is set to "mass storage", if you change it in your "connection" setting to "data storage" when you next plug in your phone, it will have all of the PC Suite settings available without any grayed out non-functionality.
Jul 22, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Hi same problem here. The "content" menu wouldn' t work, though i' ve uninstalled / reinstalled LG PC Suite many times. Why do they sell a software that doesn't even work correctly, and just let custo
The main LG PC suite screen is flawed and doesnt work for anyone, right click the sys tray icon next to the OS clock and access contents through that method, its the only way to get into it. Otherwise, go to the phone settings>connectivity and change usb mass data transfer to on to use it as a normal removable media device. Data transferred via the USB mass storage will transfer a lot quicker than using the PC suite too.
May 20, 2009 | LG KU990 Viewty
Can not connect KU990 to PC through USB
The CD that comes in the pack is does not work on Windows Vista. if you do not have Windows Vista, try to add the LG suite into your firewall (if you have one). You do that by goin into control panel and selceting firwall. Once done that go into setting then expectaions and then add a program. hope this helps.
Oct 11, 2008 | LG KU990 Viewty
Lg veiwty
First connect the phone using the USB cable provided.
Open the LG PC Suite software. On the left hand side is a connection wizard select this and then USB.
Don't change any of the port information.
Once it has connected, select contents.
go to your picture folder and then just drag your pictures onto it.
DONE!
May 29, 2008 | LG KU990 Viewty
LG KU990 PC suite installer
Take the CD and put it in another computer that can read it and copy the contents to a USB stick, then u can take it and install it into your PC.. thats what i did.... OR you can download it from http://uk.lgmobile.com/web/web.mypage.RetrieveMyPhoneList.laf
Apr 06, 2008 | LG KU990 Viewty
LG KU990 Viewty Logo
9,567 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Teet Bergmann
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
