Question about Canon EOS-AE-1 35mm SLR Camera
Camera beeps very fast won't stop
I replaced the battery and the beeping won't stop. Also the film advance won't work.
  • 423 Answers
When you press the battery check button halfway down, the camera responds with a beeping sound. The faster and louder the beep, the better the battery.
I bet your battery check button is stuck. Probably some sand or grit has gotten under there. An easy way to try and fix this is with an air compressor. Take the nozzle and try and blow out the space around the button.
As for the film advance. Double check to make sure your locking arm has engaged the film canister all the way. When you slide the arm down it. It should seat all the way.
Also, check to make sure you lined up the film guide cogs with the holes on both edges of the film.
Rob
Posted on Mar 04, 2009
I realize this question is 7 years old, but since there was not a "real" answer, I will tell you how I fixed mine extremely quickly just now. I couldn't figure out why it kept beeping until I pressed the battery test button and it momentarily stopped, AND let me depress the shutter. Ah-ha!
So I grabbed some electronic cleaner spray I had handy - you will need some if you don't have any, they have electronic cleaner at any auto parts store, Radio Shack, Amazon, etc. Don't use WD-40, it usually does the opposite of what you want it to do, long term. The electronic cleaner will clean off old deposits and dust from a circuit, and then evaporate, as well as leaving a small amount of dry lube behind. Mine came with a straw attachment on the end. If you are in a pinch, you could also try a few drops of rubbing alcohol, as that can clean off the area slightly and also will evaporate. It won't lube it like the electronic cleaner, but it will clean in a similar manner. Side note, this is also how you clean volume knobs on old receivers that sound "scratchy," you just spray a small amount into the volume pot and work it back and forth for a few minutes and you can actually feel it becoming slippery, and hear the scratch go away.
So, you're going to want to put that straw it comes with right on the button and very lightly press so only a tiny dribble comes out. Let that sit on top of the little battery check button for 30 seconds or so, then use something like a a-tip or pen cap (or whatever), and hold the button down for about 10 seconds. Release it, and let it sit there, and do it again. After that you can just push it up and down a few times and see if you can essentially suction the rest of the liquid down into the button. Then, wipe off the residue and it should be working. You can also test the shutter while you are doing this, to see if you are successful yet. After doing this, my camera stopped beeping continually, and the shutter worked like normal. I believe that prior to this, the button was either slightly pressed down, the underlying switch was slightly pressed down, or there was some dust or gunk on the circuit underneath causing the button to think it was continually depressed, so that wouldn't let me depress the shutter. Now, everything works normally.
Hope that helps!
Posted on Jul 25, 2016
Camera beeps and won't advance film
Scott, Not too hard, but give it a sharp rap on a counter top, this will some time free up stuck mechanisms in cameras.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 26, 2016 | Canon T70 35mm SLR Camera
Minolta maxxum 7000 beeping
I would look for a manual, it's been years since I played with one of these but it may mean that you need flash or the lens may not be in AF mode or the AF can not focus the camera.
Jul 08, 2013 | Photography
My Weiser powerbolt lock is beeping-changed batteries-won't stop
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Jan 09, 2012 | Weiser Lock Powerbolt 1000 Lock
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
Everything seems to function well, actually, I've never used this camera. Got if off of ebay, so maybe I was gypped. Anyways, the film advance lever seems to be stuck. It only goes half way. I can put...
If the lever won't advance even when there is no film in the camera, then I would say there is a problem. (p.s. You haven't told us the make and model)
May 29, 2011 | Cameras
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
Loud fast beeps on boot.( Toshiba Qosimo F45 )
Looks indeed as if the TAB key was stuck or malfunctioning. The most common cause for such behavior is a liquid spilled on the keyboard, a bit of which got between the layers of the keyboard membrane films and causes intermittent semi-short between conductive areas.
A trace of liquid caught between plastic films is hard to get rid of, as it practically sealed and doesn't evaporate.
If it doesn't go away, you may need to replace the keyboard, which is not very expensive fortunately,
Jul 08, 2010 | Toshiba Computers & Internet
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
501 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
