Question about Kenmore 61042 Top Freezer Refrigerator
Not working at all
Other than the light, nothing is working. No clicking, no humming, etc...
In garage over the winter
Sears Kenmore 253.62802202
Where do I start? Cap, Relay, Compressor???
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, you mentioning those parts indicate that you are familiar with electrical components at least with respect to your unit. To perform diagnosis, you would need a DVM/VOM to check for the presence or absence of voltage.
Foremost to check would be the flow of power. It is known that power enter hence the light. From thereon trace the voltage since the voltage will branch from there. The thermostat acts as temperature controller, simply stated, it acts as a switch to supply power to the compressor. In some versions, the thermostat goes to a controller board rather than straight to the compressor motor. If this is the case, then the motor would be activated by a relay. In short, a lot to check.
One particular area to check would be the common terminal block where all the main wire/harness meets. In most models, there would be terminals/connectors that would need looking into and even cleaning to ensure no corrosion. As always be reminded of safe working practices when checking live/powered units.
Pls postback updates. Good luck and thank you for using FixYa.
Posted on Feb 02, 2009
    Master:
  • 505 Answers
How old is the fridge
  • maby needs re gassing as you said the light works i cant see it being the power board
  • Kenmore Master
  • 19,396 Answers
If it is not working at all then it is a lose contact on power wiring, or a defective control board.
I have a Sears Crafstman Garage door wireless opener. Model 139.53615SR . The door hums but nothing happens. The chain doesn't move. The springs on the door broke last year and i replaced both of them....
My plastic gear stripped soon after a spring broke. I think the broken spring put a huge load on the opener that day and ruined the gear. Replacement wasn't too hard. It will be obvious when you remove the cover if the gear is stripped. Here are instructions:
http://tinyurl.com/gearfix
Dec 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage opener went up and the stopped mid way.. motor is humming but nothing moving.. sears 1/2 horse model 2000. Thanks John
Tries unplug,replug it back like about an hour latter.The unit now should be resetting itself,should work again.Still have same problems later,the motor should be check out and fix.
Dec 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
AFTER A RECENT ELECTRICAL STORM AND A NEARBY LIGHTENING STRIKE THE GFI PLUG BLEW. ONCE RESET THE GARAGE DOOR MOTOR WILL NOT FUNCTION. LIGHTS COME ON - I RESET THE REMOTES BUT NOTHING . AT FIRST THE MOTOR...
I would pull the logic board and check for burnt or missing traces on the printed circuit. Garage door openers hate electrical storms. I really doubt it got to your start capacitor.
Jun 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door worked, 2 hours later didn't- just hummed good weather
If it just hums when a button is pressed it could be the start capacitor. This sits next to the motor and is about 5 inches long and about as big around as a silver dollar.
May 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door hums but does not open. It had
Sounds like you have a bad start capacitor. It sits next to the motor and is about the diameter of a silver dollar and about 5 inches long. You can get one at any good door opener service company.
Feb 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor clicks but will not open door
motor is over heated shut down unplug 30 min
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Oct 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kenmore 61042 Top Freezer Refrigerator Logo
21 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
