HP zv5000 turn on cycles between a blank screen with blue lines
HP zv5000 turn on cycles between a blank screen with temp blue vertical blue lines and the HP Start up page where it asks for you to press to change boot order. The hard disk light contantly flickers during this time. Thank for any help.
  • Colin MacKenzie Computer Force of Dawsonville
    Put a bootable CD in the CD drive and see if you can boot the laptop.
    or, remove the hard drive and place it in an external USB enclosure. Plug that into the USB of a working computer and see if you can access the HD. If not the HD is bad. If you can you may have to reinstall your OS. Note: if you can get a copy of Live Linux from Ubuntu you can boot the Live Linux and see if you can access the HD. If you can not the HD maybe bad. There is always a chance the controller is bad on the Mother board.Here is a link to Ubuntu Linux
    http://www.ubuntu.com/getubuntu/download
    if you boot that from your CD you have the option to run Ubuntu from the CD. You can then try and access the HD.
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
Sound no picture
A educated guess here (model is a rather old Sony) this set will blank or shut the tubes off if loss of vertical or horizontal deflection---the slight line at top suggests vertical
What I have done to confirm this is either use a scope and check for deflection or turn blue screen up slowly(blue is less likely to burn the tube screen) and see if just a line.
The set blanks the tubes to prevent a line being burnt instantly at normal brightness (all concentrated into a line) on the face of the tube.
If you are technical and have a volt meter you may be able to locate online a free copy of the service manual to check voltages etc.
Dec 03, 2012 | Sony KP-61V85 61" Rear Projection...
I attempted to upgrade the RAM on my HP Pavilion zv5000. (the one under the keyboard) when I tried to turn it on, there is just a blank screen. Any idea what the problem is? The laptop was installed...
According to the link below you can do the upgrade. If is not working, make sure you have the memory seated correctly, then mix and match the memory and switch slots to find the problem memory. It may be incompatible with either the motherboard or the other memory sticks, or just a bad stick.
http://www.insidemylaptop.com/upgrading-memory-hp-pavilion-zv5000-series-laptops/all-comments/
Apr 21, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
Cheers!!!!
May 25, 2009 | HP f2105 Monitor
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
When I turn it on, there are blue lines that run down the LCD
There is a loose connection on the screen you need o call in an repair man.
Jan 06, 2008 | HP Pavilion zv6005us Notebook
HP pavilion ZD7255EA
the card probably has a loose chip. needs repair.
Nov 21, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
