Question about HP OfficeJet 6210 All-In-One InkJet Printer
Thanks.how do i remove the cartridge for replacement
It is a helwet pacard photosmart hp2610 printer
    President:
  • 2,692 Answers
Hp2610 is not reconizing a brand new color cartridge
Hello kag_avg7208,
Welcome, and thank you for using FixYa!
I believe your issue is that the contact points within the printer could be dirty.
Clean the contacts within the bay, where the cartridge goes in, with a #2 pencil eraser; then install the cartridge.
If the cartridge still will not recognize, then try another cartridge.
If this cartridge still doesn't work, you will have to replace the printer.
Have a great day!
Sep 11, 2011 | HP Photosmart 2610 All-In-One InkJet...
Hi have a hp2610 keeps giving error message remove and check cartrages.this done then reads remove and check cartrage on right.
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Sep 02, 2010 | HP Photosmart 2610 All-In-One InkJet...
Difficulty in downloading the software
From the manufacturer's web-site:
http://support.hp.com
enter '2610' and select your printer.
Select the device-drivers for your Operating System.
Download them. Install the drivers.
May 13, 2010 | HP Photosmart 2610 All-In-One InkJet...
HP2610 will not print. Getting "remove and check cartridge..."
I just had this same problem (cartridge on left). Something had broken that was holding the little metal wire in place--the one that sticks out along the bottom where your cartridge goes but apparently moves to the side when you install the cartridge. My guess is that this wire may make some sort of electrical connection that indicates when the cartridge is all the way it (if it doesn't move--or if it is broken--it doesn't make the connection and it thinks something is wrong with the way the cartridge is installed. So I used a strip of tape to hold the wire in place on the side of the cartridge compartment (it had been loose and flopping around), and it works fine now.
Oct 20, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp photosmart 335 - cartridge failure
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart 335 InkJet Printer
Why can't I Uninstall Hp2610 software for Reinstall?
Hi all of you
to uninstall you have to clear the bended print job, then go to Add/Remove.
hope this helpful for you,
thanks
Hamedo
Nov 17, 2008 | HP Photosmart 2610 All-In-One InkJet...
Alignment
When this printer first came out, I got all excited and bought one, within six months I had it on the shelf, and went back to my HP2610, which I am still using. I personally think that this is the Edsel of HP printers.
Jun 27, 2008 | HP Photosmart 3210 Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
