Question about Samsung J700 Cellular Phone
Phone freeze what does this mean?
The phone is asking to enter password, no password was set up, put in pin but then the phone comes back with message saying phone freeze pls help.
  • Anonymous Feb 03, 2009
    phone keeps freezing cant use it
    any ideas
    emma
4 Suggested Answers
  • 20 Answers
SOURCE: phone freeze unlock code
You have to send the phone away for repair.
Posted on Jan 01, 2008
Bajanguru
  • 7752 Answers
you need first to have the phone unlock by taking it to a mobile store, then also have them firmware reflash on the phone.
Posted on Jan 13, 2008
phone locked forgot password
Posted on Jul 27, 2008
SOURCE: I was setting mobile tracker
Try with password: 1122
Posted on Feb 26, 2011
What's the phone freeze password for samsung gte3309t please help
If your phone is region locked you need to remove this first. A region lock is activated if you buy a phone in one region (e.g. Europe) and take it to another region (e.g. USA) without first using the original provider for 5 minutes (calling any number). Most new phones with Android 4.3 or higher come with region lock and you can also recognize it from the following sticker on the box of the phone:
To deactivate the region lock enter the code next to 'Extra' from the codes we provided when the phone asks for 'Network Unlock Pin'
Unfreeze instructions
1. put non accepted simcard inside phone
2. start phone
3. (enter pin if set)
4. phone shows 'phone freeze' message
5. (If you have touch screen only model: hit call button)
6. Enter unfreeze code
Important: the digits entered will not be displayed on the phone's screen.
Important 2: On some phones you need to confirm the unfreeze code by hitting '#' button after the last digit of your unfreeze code
Importante note: there is a free method going around doing NV Rebuild using some codes, if you have used this method it is very likely non of the above methods work for you. If you did this talk to support to find a solution. You will need to flash the phone. No refund will be provided in this case.by Samsung Galaxy J7
Aug 23, 2014 | Cell Phones
Phone keeps saying invalid sim
Messages When You Turn on the Phone
  • When turning on your phone you may find a message requiring you to take a certain action before you can use the phone. If the message says "INSERT SIM," make sure the SIM card is installed in the phone or that it hasn't become loose. The SIM card is located in the battery compartment. Remove the battery cover and the battery. The SIM card should be located near the bottom of the phone under the metal hinge. Insert or secure the SIM card with the contacts facing down, reinsert the battery and batter cover, and turn your phone on again.
    If the message reads "PHONE LOCK," the SGH U600's automatic locking function is enabled. Enter the phone's password to unlock the phone.
    When using the phone for the first time, you will be prompted to enter a PIN. The PIN is given with the SIM card for your phone. Enter the PIN number exactly as given. You may also have the "PIN Check" feature enabled on your phone, which will require you to enter the PIN every time the phone is powered on. You can turn off "PIN Check" in the "Settings" menu.
    A message asking you to enter a PUK means you attempted to enter the PIN number three times and failed. You must contact your service provider to get a PUK.
  • Read more: Samsung SGH U600 Troubleshooting ' eHow.com http://www.ehow.com/way_5408527_samsung-sgh-u600-troubleshooting.html#ixzz11rVbifG3
    Oct 09, 2010 | Samsung SGH-U600 Cellular Phone
    I am getting a message PIN Code Blocked. Enter PU...
    It means that the usual PIN code used to unlock the phone has been entered incorrectly too many times. To get around this you must ask the network provider for a PUK code which unblocks the SIM and allows the user to set a new PIN code.
    On most phones, the PIN only applies to the SIM, not the phone, so if you fit another SIM card you can continue to use the phone but will have a new phone number.
    May 20, 2010 | LG Xenon GR500 Cell Phone
    Nokia 6085
    Complete information :
    The SIM card protects your subscription and not the phone from unauthorised users. If you change SIM cards you can still use your phone with a new SIM card. Most SIM cards are blocked at the time of purchase. If your SIM card lock is on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
    If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
    Note:
    card (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. You can edit your PIN and select a new four to eight digit number
    • If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
    • If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
    To unblock your SIM card:
    1. When PIN Blocked appears enter your PUK > OK
    2. Enter a new four to eight PIN > OK
    3. Re-enter the new PIN to confirm > OK
    To edit your PIN:
    1. > Settings > the General tab > Security > Locks > SIM Protection > Change PIN
    2. Enter your PIN > OK
    3. Enter a new four to eight digit PIN to confirm > OK
    To turn the SIM card On /Off
    1. > Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
    Jun 15, 2008 | Nokia N73 Cellular Phone
    Unlock puk code
    samsung phone "PUK blocked Call SOS" - i have the PUK code but cant put it in as its not giving me any option other than call sos. how do i put the code in to unlock it.
    Jun 08, 2008 | Samsung SGH-D500 Cellular Phone
    Sony E k550i
    What kind of code is it asking for?
    If it ask for a PIN code then it means it's asking for the password/code you have entered on your SIM card. If it asks for Security code then that means it's the password/code for the phone.
    Entering three invalid PIN codes on your phone then your PIN may be locked and you can only unlcok it by entering the PUK code on your SIM. PUK code is available on the sim card pack. Once it's ented, you have the option of changing your PIN code. Just be sure to remember your PIN code so the same incident won't happen again. If it ask for security code, enter the code you have for the phone but if you don't remember setting a security code, then you may try the default security code of Sony Ericsson phones which is 00000.
    May 05, 2008 | Sony Ericsson K550i Cellular Phone
    Ok I have an at&t Motorola c1681 go phone and i left the keys unlocked and put the phone in my back pocket i took it back out to make a call and it was asking me for a PUK code? what is that and what...
    Note:
    To edit your PIN:
    Apr 19, 2008 | Nokia N95 Cellular Phone
    I need my 4 digit id code b 4 i can get my puk number but i forgot it
    you have to phone 07973100450 from a land line. it will ask you for your phone number a few times then it will pass you to  a REAL person who will ask you ask you a few security questions like what are the last four numbers of your top-up card and vol lia that is how you get your four digit id code!!!!!!!
    Feb 22, 2008 | Nokia N73 Cellular Phone
    I've tired to set the PIN code for my Nokia 6085 phone but I cannot. I've entered the PUK code but now it says, "Enter new PIN code:" What do I do? I've entered a code I wanted and other ones on my...
    hi
    as youve entered the puk code, it asks for the new pin code, the default code was 1234 right? so if you are going to try the new pin code yu can either invent a new pin code or just enter the default code.
    hope this helps.
    Jan 24, 2008 | Nokia N73 Cellular Phone
    Phone freeze unlock code
    Jan 11, 2008 | Samsung SYNC SGH-A707 Cellular Phone
    Samsung J700 Cellular Phone Logo
    581 people viewed this question
    Top Samsung Cell Phones Experts
    Fotis Papastamatiou
    Bill Long
    Mike Cairns
    Mike Cairns
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
