Question about Cisco Systems CiscoWorks User Guide Software (CWW-DOC)
Ciscoworks LMS 3.0.1 User Tracking reports no ip address
I have Ciscoworks LMS 3.0.1 and Campus Manager 5.0.4 installed.
Around 2250 host has been discovered by the User Tracking Acquisition
Some weeks ago i have installed many updates, and now the user tracking acquisition still discover the hosts but only by mac-addresses.
No ip addresses and no hostnames arer listed sothat the only way to find a host is to know its mac address.
Could you please help me.
Thanks in advance
Karim Niang
2 Suggested Answers
kvgopi
  • 74 Answers
SOURCE: pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Posted on Mar 17, 2009
Can't find IP address 192.168.1.2
Your IP address 192.168.1.2 is a Local IP address. Local(Computer) IP address ranges from 10.0.0.0 to 10.255.255.255, 172.16.0.0 to 172.31.255.255, 192.168.0.0 to 192.168.255.255. Normally you can login the Local IP address within a single building (or) campus using LAN. If you need to access around the world, it should be a Public(Network) IP address. To check your Network IP address, visit IP-details.com .
Apr 16, 2013 | Zyxel Wap3205 Wireless N Access Point -...
Network installation error access denied on hp lj1020 my printer was working fine. i have installed printer on xp m/c its working fine but when i install it on win7 it give error print spooler error or...
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
Dec 19, 2010 | HP LaserJet 1020 Printer
NComputing connected to existing Lan network
If your existing LAN has DHCP assigned IP addresses, you will be good to go. If you have statically assigned IP addresses, you will need to enter them in manually into the device. Their website has a very good instructional video on the procedures to hook up the devices. It will work with standard cat5,cat5E, or cat6 wiring.
Apr 29, 2010 | NComputing L230 Network Terminal
Pix 515 E allow few websites only.
Eg.
1. go to dos prompt
2. type "nslookup"
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Jun 22, 2008 | Samsung ML 2010 Laser Printer
Scan a document to my file server
that's in scan settings from print manager..
May 03, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
Jan 31, 2008 | Samsung CLX 3160fn All-In-One Printer
Canon ir2016 system error E007
canon ir 2016j photo copier displayd system error E007.
how to solve this problem?
Nov 30, 2007 | Canon PC-940 Black and White Copier
My P310 can not get an IP address from the ISP to connect to the Internet, what can I do?
Currently, there are various ways that ISPs control their users. That is, the WAN IP is provided only when the user is checked as an authorized user. The ISPs currently use three ways: 1. Check if the 'MAC address' is valid 2. Check if the 'Host Name' is valid, e.g., @home 3. Check if the 'User ID' is valid, e.g., RR-Toshiba Authentication Service, RR-Manager Authentication Service, RR Telstra If you are not able to get the Internet IP from the ISP, check which authentication method your ISP uses and troubleshoot the problem as described below.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Computers & Internet Logo
691 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
