Winds open the icons,rigitkyy,liftkey,starbutoptins not comingsir
Rafi
hyd
  • 1 more comment
  • Afolabi Bello
    Afolabi Bello May 11, 2010
    I can really understand what you mean. Can you please explain yourself well, so that I will know how I will help you. Thanks
  • Afolabi Bello
    Can you kindly explain yourself well? I can really get what you mean...Please, explain the problem well, so that I will know how I can help you.
  • Ekse May 11, 2010
    rafi
    hyd??
  • 101 Answers
Plz tell me wat you want dear "winds open the " wat is this
Posted on Oct 29, 2009
  • karanvir singh
    karanvir singh Oct 29, 2009
    plz tell me wat you want dear "winds open the " wat is this
2004 LZ27KC604 Wen pushing levers to go forward, machine jumps and lurches
Sounds like you have air in the hyd. lines You need to bleed the air out. You can raise the back wheels off the ground and open the valve on the hyd drive motor just enough to let the air out and run the machine for a half hour on low speed and another half hour on high speed and it should correct the problem. You need to do this on each motor or wheel. Be sure you have the correct weight oil in the unit as well. Hope this helps.
May 26, 2016 | Garden
I have 2010 town county won't shift trans just rises when on freeway installed another trans does the same thing what is it
Hi Rafi, Im AL the owner of Big As Auto Repair.
Rafi, your explanation sound like you may have a restricted transmission cooler. If the cooler is restricted then trans-pressures or affected and could cause the issue your taking about. If you have access to shop-air you could blow through the cooler and see if that changes the way it shifts. If it does then go to AutoZone and get a trans-cleaner and fill the cooler and let set a few hours and then blow the cleaner out with shop-air. Hope this helps and please visit my auto-repair-website here: http://www.bigasautorepair.com/
Dec 24, 2015 | Cars & Trucks
4496 CASE TRACTOR .Ran out of hydraulic oil , filled up and bleed lines , still have no steering and the brake is out ,.What valve is locked in ?
by bleeding lines where exactly did u do this ? , the place id try 1st is right off the pump to the dist block (carefully!!!) if no pressure there then a more aggressive repurdge of hyd sys is needed using another machines hyd system connected to remotes inputs off the dist block
reason 4 this is that hyd oil pumps don't just pick up oil again when run dry an have to be helped to pressure up again , Also another possible cause is that pressure relief is stuck open , this doesn't allow any pressure to build up
Nov 13, 2015 | Cars & Trucks
What is destroying front hyd. seals?
Mechanic is not doing the job correctly and should be doing subsequent repairs free or paying for someone else to do it right.
Dec 09, 2014 | Cars & Trucks
No fluid from rear pump 410 john deere backhoe
1st ck hyd tank for fluid level and fluid quality 2nd remove and ck hyd filter for blockage (note some hyd filters have a water sensing block valve inside) 3 rd verify that fluid is reaching pump , pumps will make horrible noises with no fluid in them , if all are well replace pump , and ck that bypass valve is not stuck open and is set correctly (some are internal to pump )
a method i've been sucessful with is to temp power hyd system with remote from another working tractor/bobcat , this sometimes unsticks bypass valves , but unless your familiar with what fittings do what and such I don't recomend this action for novices
Mar 19, 2014 | John Deere Garden
Electrolux washing mechine spare parts where are available in hyderabad.
  • ADEEB ELECTRONICS & HOME APPLIANCES, NEW MALLEPALLY, 500004, Hyderabad, Andhara Pradesh
  • ANAND ELECTRONICS, DILSHUKANAGAR, 400025, Hyderabad, Andhara Pradesh
  • ANJALI ELECTRONICS PVT LTD (HYD), NAMPALLY, 508373, Hyderabad, Andhara Pradesh
  • ASCOT ELECTRONICS (HYD), SULTAN BAZAR, 500095, Hyderabad, Andhara Pradesh
  • BAJAJ ELECTRONICS, NR. TELEPHONE BHAVAN, 500004, Hyderabad, Andhara Pradesh
  • BALAJI REF & AIRCONDIOTIONING WORKS, SHOP NO. 1-134,OPP.LANE SHOBHANA TALKIES,, 500042, Hyderabad, Andhara Pradesh
  • BALANAGAR ELECTRONICS, 2-101/6&7, OPP: SHOBHANA BUS STOP,BALANAGAR, 500042, Hyderabad, Andhara Pradesh
  • BELL ELECTRONICS (HYD), R.P. ROAD, 500003, Hyderabad, Andhara Pradesh
  • BHARAT ELECTRONICS (HYD), BADAM BHAWAN, 500059, Hyderabad, Andhara Pradesh
  • BHAVANI ELECTRONICS, 9-1-45/7, LANGAR HOUSE, 500008, Hyderabad, Andhara Pradesh
  • VISION ELECTRONICS&HOME APPLIANCES, PLOT NO.46 , TULIPMANSION, 121212, Hyderabad, Andhara Pradesh
  • YASH ELECTRONICS, DEVA SADAN COMPLEX, 500047, Hyderabad, Andhara Pradesh
Dec 03, 2010 | Electrolux EWDW6505GS Fully Integrated...
Need hyd Motor hyd p/n 23-3802 pump hyd p/n 23-2058 mfg sundstrand explain me, how to order and where? thks
Call Nova Hydraulics 317-322-0242 x103.
You will need the last 6 letters of your motor code.
A correct code example 23-3802AN-JSBJ.
Jun 03, 2010 | Danfoss Sundstrand-sauer-danfoss...
Lower half portion of the horizontal screen black
hi rafi,
check if problem occurs with another computer, hook up another monitor to your computer to check if your graphic card is making trouble.
if it the monitor, and it still is under warranty and you did not damage it, just return to place of purchase and let the paid pros work their magic1
Good luck
Sep 07, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
About of sparkplugs calibration
I am assuming that you are asking about the spark plug gap. Hope this helps
GASOLINE ENGINE TUNE-UP SPECIFICATIONS Year Engine VIN Engine Displacement Liters Spark Plug Gap (in.) Fuel Pump (psi) Ignition Timing (deg.) Idle Speed (rpm) Valve Clearance (in.) MT AT MT AT In. Ex. 2005 8 2.8 0.042 50-57 - - - - HYD HYD 6 3.5 0.042 50-57 - - - - HYD HYD
Mar 28, 2009 | 2005 Chevrolet Colorado
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
