Question about Hoover Washing Machines
Belt keeps coming off hoover nextra hnl 3416
Belt keeps coming off when spinning and is very noisy i think the bearing has gone is it easy to change
  • 112 Answers
It sounds like the bearing.
It`s quite a big stripdown job.
If you are good at DIY then you should be able to do it.
Just make sure the drum isn`t damaged where the bearing fits.
Posted on Feb 02, 2009
Hoover nextra washing machine model hnl 6166. how do i replace noisy drum bearings
If you are mecahical inclined look up the model and seriael
# on the web. ask them to send you a book of maitence on it and this should show you how and where the bearings are and where to get new and how to replace them.
May 10, 2011 | Hoover Washing Machines
My Hoover HNL 842 wont drain/spin. Have removed/cleared filter, pump is working. pipes are clear. Now what?
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Mar 23, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Hi the belt on our hoover hnl 6166 nextra will not stay on. The motor and the drum seem to be out of alignment and there are no broken screws or bolts or wobbles. Any ideas please? Thanks Robert.
I would suggest that the drum is out of alignment because the main bearings have failed, or the drum shaft has collapsed due nto corrosion.
Spin the drum by hand, and listen for any noise, there should not be any, and see if the drum rotates centrally in relation to the outer drum
Feb 02, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Wont spin dry, drum wont empty
Sounds like your pump is bad or you have a belt slipping. Get me the model number and maybe I can give you more detail.
Feb 03, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover new wave1200f noisy on spin cycle
I had a heavy knocking noise and found it to be the counterweight ( or stabilizer) whiich looks like a lump of cement, had come loose and was slapping around. Managed to tighten bolts holding it to the drum whiich solved the problem.
Apr 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Washing Machines Logo
268 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
