Question about Lenovo R Series Notebook
Problem related to formatting
My system is lenovo 3000 Hseries (intel) i don't know how to format by setting bios and vagera please guide in formatting hard disk and how to set a bios it is not laptop
  • Ekse May 11, 2010
    To format a hard drive you need to use a windows installation cd for example. There is noting you can do in bios to format a hard drive.
    Can you clarify what the actual problem is?
I want to format my lenovo 3000 n100 laptop,but in boot screen it is asking for password and I forgot my password. My laptop is also not startin.Please help.
If you are able to open your laptop, take out the little battery for an hour or longer. This clears your bios, perhaps there is a jumper nearby to speed this up. All bios passwords are gone then.
Next you open your bios and make your cd/dvd the first bootdevice.
Insert your windows and follow instructions. When asked where to install windows you delete all drives and then create a new drive to format and install windows on.
Feb 24, 2014 | Lenovo 3000 N100 0768 - Pentium Dual Core...
How do i restore my lenovo 3000 back to factory settings. i have no disks that came with it
Power on the computer and during bootup holding onto F2 key will lead you to BIOS. Browse to Intel AMT. Change the settings to "Disable". Save the settings and exit. After the BIOS settings are saved the system will automatically reboot.On the power on you will see a message do you want to continue.Select yes.You will need to enter Bios again. Browse to Intel AMT again change the settings to "Enable".Press exit saved settings.After the BIOS settings are saved,and powering on the system you will have to press ctrl-P to configure ME/AMT again.Hope this might help.
Aug 18, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
How to format a lenovo laptop
If you have the OEM Lenovo XP disc are you have to do is insert and follow the instruction. If you are using off the shelf software, then switch the BIOS SATA to compatibility mode, and boot from your CD drive with the disc in it, and format the harddrive followed by installing the software.( like Windows XP or the Vista)
Jan 04, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 N200 Not recognize my WD Scorpio 160Gb HDD sata
When a hard drive is not recognized in the BIOS then it indicates a hardware malfunctioning. In this case, service is required.
Sep 15, 2009 | Lenovo 3000 N200 Intel Pentium Dual Core...
I have lenovo Y410 laptop i have deleted all the partition in my hard drive now i am tring to install windows vista but problem coming- " please ensure the disk controller is enabled in the system...
did you recreate the partitions you deleted? sounds like there's not a partition on the drive. when you boot the machine press the F1 key. that will take you to the system bios.. then press F9 .. that will set the bios to the factory default settings.. then press F10 that will save and exit the bios. If you have a partition and its set active..you should be able to procede from there. If you continue to egt the error message.. you need to verify the part5ition is valid and active. formatted would help as well..
May 09, 2009 | Lenovo 3000 Y410 Laptop
Lenovo startup problem
hi thanks for using fixya!
I suggest if you can try to make a windows update for your system. Then try to make a disk defragment. And try to conduct a full scan of your anti-virus. Then observe your system, if all same problem, I suggest that you format your system.
If you need further assistance, let me know. regards!
Apr 26, 2009 | Lenovo 3000 N200 Intel Pentium Dual Core...
Sound driver lenovo 3000 c200 laptop
open your control pannel and click on user settings. from here you can change administrative option!!!
Jul 29, 2008 | Lenovo 3000 C200 Notebook
Reset motherboard bios
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
85
Dec 26, 2007 | Intel D845GVSR Motherboard
Lenovo R Series Notebook Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
