Question about Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card
My pc give no audio device
When i choose sounds & audio devices in control panel,i can see a messege as "No audio device"
  • 2 more comments
  • Anonymous Feb 02, 2009
    my pc give no audio on switch to songs
  • fredbrain Feb 07, 2009
    MY NAME IS FRED REPORTING FROM GHANA, NO SOUND FROM MY IBM INBUILDT COMPUTER
  • Anonymous Feb 12, 2009
    my pc shows an error message that no sound driver is installed
  • Steve Draper May 11, 2010
    Do you have a sound card fitted ?
    Try to uninstall it and boot your computer again.
    Please let me know what happens.
    Problem Solver:
  • 4 Answers
Try to install *********** board driver / software...that contains driver for your sound card...
Posted on Feb 02, 2009
I have no sound. maybe my computer has been muted
Check that sound drivers are ok as follows
  • Open your start menu (right-click on the "Start" button and choose "Explore"), and find the "My Computer" icon. Right-click on it and choose "Properties" from the submenu. Click on the "Hardware" tab and then the "Device Manager" button.
  • Expand the "Sounds, video, and game controllers" heading to find your sound card. The name will depend on what sound card is installed on your PC. It will most likely have a name containing "audio." It should look something similar to the example above. You'll know immediately if there is a major driver error because an exclamation point (!) will show over the card's icon.
  • Double-click on the name of the sound card to open a new window. In the new properties window click on the "Drivers" tab. If there is no "Drivers" tab then you chose the wrong sound device. Go back and try again. On the "Drivers" tab, click the "Driver Update" button. Follow the Wizard's onscreen instructions to update your driver. You can also contact the manufacturer of your PC for the most recent audio drivers. They can usually be found online.
if the drivers were OK, proceed as follows
You can check the system volume and adjust it as follows
No. Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Sounds and Audio Devices.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Move to Sounds and Audio Devices by pressing the arrow keys.
  • Press ENTER.
3 In the Sounds and Audio Devices Properties dialog box, on the Volume tab:
  • Adjust the sound volume by moving the Device volume slider.
  • Select OK.
  • Adjust the Device volume by pressing the RIGHT ARROW key for higher volume (louder), and the LEFT ARROW key for lower volume.
  • Select OK.
4 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
Apr 25, 2011 | Computers & Internet
Sir, i have downloaded the drivers for audio for c765tu ,bot wheni installed it,it still not works.also checked from the control panel,there it is not enabled. can u please give me a complete solution
Thank you for choosing FixYa. I suggest try going to Device Manager and see if the sound there is not installed properly, If not just right click on it the choose Uninstall, after that try to Reinstall the sound driver that you downloaded. The Device Manager is also in the Control Panel.
AnEspera
Apr 23, 2011 | Compaq Computers & Internet
My Dell Dimension E510 cannot pick up any voice recording from my various mic inputs. I have fiddled with volumes of each respective input (line in, rear mic, mic jack) to no avail, and when I try to use...
This sounds like you have a voice morphing program installed. A morph program is useful for distorting your voice and special effects, but it also takes over your mic controls. Go to the control panel and choose sounds and audio devices, then look for the default device under sound recording and make sure your record device is the same model as your sound device and that it says INPUT. Another problem occurs if you right click your little sound/audio icon on the taskbar and choose open volume control then left click. Do that now and choose, options, then properties. Now on mixer device, choose one that says input. The white window on the bottom of that panel will show you several devices, check mark them all and click ok. Now manually select MIC as your default sound input device and close then try again.
Mar 09, 2010 | Dell Dimension™ E510 PC Desktop
I get this messeg when i try to play muice or vids how can i fix this.(Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device...
Put your PC on, and left click at Setting, Control panel, and at the Add Hardware wizard. Follow the instruction prompted to know if the Sound Card is installed. If it is not, Have it installed. Then, back at the Control Panel, left Click System, Hardware, Device Manager, and finally the Sound, Audio device, to find the status and property. Then, you have to reinstall the sound driver software thru a CD if you
have one. If none, get connected to the internnet and
have your download. Just type at the Search engine
blank (Free download Sound driver software). Upon
reaching the site, get your download. Upon completing the download, ga back to your PC. Click
open, the download and install it in your PC. Upon
completing the installation, test it thru the Windows
Media Player. Hope this works and solve your
problem.
Nov 24, 2009 | Computers & Internet
How do i connect an external microphone to my philips freevents x55. only the built in microphone is working. an externally connected mic does not over-ride the internal one?
Your default recording device is still set on the built-in mic.
In Microsoft XP...
Choose Start > Settings > Control Panel and double-click the Sounds and Audio Devices tab
Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
In Vista, choose Start> Control Panel > Sounds and click on the Recording tab.
In both instances, choose your external mic as the default.
Windows XP 1 Choose Start > Settings > Control Panel and double-click theSounds and Audio Devicescontrol panel.
2 Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
Oct 04, 2009 | Computers & Internet
My computer can't play no sound I went to sound
When did sound work fine on your computer. Try this :-
Open device manager(Start - run - type devmgmt.msc) and expand sound video and game controllers.
Right click all the submenu underneath and choose uninstall.
(Note : All the menus will not give you an option to uninstall, dont worry)
Uninstall those which gives an option followed by restart your PC and see if it works.
If it doesnt, click start - run - type services.msc and look for windows audio service - make sure ot is automatic and started, if not make it.
Let me know the status.Awaiting response.
Thanks.
Sep 08, 2009 | Microsoft Windows XP Home Edition
My sound on my HP Pavillion Entertainment PC doesnt work anymore
Try downloading this (The audio driver)
If that does not work, go to control panel and to "Audio devices and sound themes", Right-click on a empty spot in the window that pops up, and choose "Show disabled devices" and "Show disconncted devices", if you see a icon that is called internal speakers or speakers..something similar. You have to right-click it, and choose Use as default.
Jul 24, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
I need my volume to be magnify
You need to know what operating system your PC use. This is a simple steps to make more louder the sound in Windows XP system:
  1. Click [Start] menu, choose [Settings] and then click [Control Panel], finally chose [Sounds and Audio Devices]
  2. On tab [Volume] od Sound and Audio Devices Properties, move Device Volume Control slider from "Low" to "High" position.
  3. Click [Apply] at lower right most corner part of the panel
  4. Click [OK]
  5. The volume has become louder
Note: I think, adding a pair of stereo active speaker is the simple way instead of getting more louder sound of the PC's sound card.
Nov 26, 2008 | Computers & Internet
Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
