External hard disc not accessible
My external hard disc refuse to open when i connect it to my system through a USB CABLE. i named it Awolowo HDD (G) but now it is seen as Hard Disc (G) when i open my computer. before when i install it, the autoplay runs and opens it the hard disc, but know, after several minutes of connecting it, the autoplay runs but it doesn't open the external hard disc. trying to open it from ''My Computer'' page, it takes so much time and the page hangs and refuse to work until i force it to close with 'End Task' command. please help, i have a lot of data that should not loss or i put myself in trouble in my office.
  • 58 Answers
Hi there...if this thing happen to your external HDD you have virus in your external hdd. so the solution is connectthis external to your pc/notebook then if already detect by system don't try to explore it or else just click cancel if system ask at popup windows.
in windows explore at your exernal id double right clik and choose format with default allow size...wait for a minute ( depend how big the size of your external). and don't forget to close all program first (music etc) when you formatted.
about geeting your external data back you can use program Office Recovery.install it at your pc and you can backup your data using : office recovery--media heal for hard disk....
good luck
Posted on Feb 02, 2009
External Hard Disk
1. External powering try changing the adaptor 2. Powered by USB try changing the USB cable 3. Try connecting to other computer 4. Check for any specific error displayed by Mac or ur PC 5. Try changing the disk name assigned to ur external HDD using disk management in PC 6. Hardware problem if under guarantee get it changed else go for data back up and solve if any bad sectors have come up in the HDD 7. You can check for software a that try to repair bad sectors in a HDD but it takes lot of patience for the same
Jan 01, 2014 | Western Digital Computers & Internet
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
When i inserted an external drive to my pc, then i want to access to this external drive, it says the request could not be performed due to io device error.
io error means that the "Input/Output" is not working. This could be due of different reasons. Try the following:
1. try it on another computer if it works, it's something with your computer. Could be hardware (e.g. loose connected cable or driver) 2. try another USB cable, if it works, its due of the USB cable (or the cable has loose contact)
Mar 11, 2011 | Western Digital WD 250GB ELEMENTS 2.5 INCH...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Hi ,my name is sameer i have 120gb lacie external hard disk,but is not suporting usb cable how can i change case pls help.............
just open your external HDD case, look for the connector (SATA or IDE), so buy new external harddisk case according the connector type.
Dec 20, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My external harddisk is not detecting
hi kiran,
If you are using Windows 98 then you have to istalled driver for your external USB HDD.
If you are using Windows XP/Vista then the masstorage drivers for USB HDD is allready installed in your system, as it comes with the OS.
Some time due to conflict or bad contact your system might not read the USB devices:
  • Be sure that switch is on (if there is any switch in USB HDD).
  • Try to check the connection.
  • Try in different USB port.
  • Also check the USB cable is good.
If still no success try to use in another system and let me know your feed back.
Thanks
Iqbal
May 21, 2008 | Seagate Barracuda 7200.7 200 GB Hard Drive
Secured and compressed jpgs will not open
Hello patsyzara
(01) 1st, for now (as a precaution against data loss), please, don't add or delete anything to or from that external HDD (hard disk drive)
(02) Just to make sure, the photos and not just a catalog of the photos were originally stored onto the external HDD, yes?
(03) Do you still have access to the computer where you originally had the external HDD connected at the time you encrypted the files (photos)?
Even if the protected files were on the same external HDD that you are using now, the protection software is possibly associated w/ the computer on which the files were fist stored.
(04) Please, tell us exactly what mechanism (the name of the software, etc) you used to originally encrypt these files.
(05) Did you recall if you used software that came w/ the external HDD to encrypt your files?
(06) Please, tell us the the following:
(A) The operating system that was installed on the previous computer you're referring to. (Windows 2000, Windows XP, etc.)
(B) The model number of your Freecom external HDD. (look for a sticker or any markings on the case).
(C) The name of the encryption software if you can remember.
(06) If you still have access to the original computer, connect the external hard disk to that computer and tell us if you can see the files again.
(07) If you can, decrypt the files and then transfer the external HDD to the new computer.
If you need assistance w/ ANY of these steps or have any questions at all, comments, observations, etc., please, post back here w/ them. We will continue to work w/ you on this issue until it is resolved or we reach an impasse.
Thank you
BJ @:)
Apr 15, 2008 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
529 people viewed this question
David Payne
David Payne
