I did a re-installation on my PC of Windows XP. the PC is supposed to be on a Local Area Network. After the formatting, i lost the machine's networ drivers. which site can i use to get the drivers. lease help
  • Jinan
    Jinan May 11, 2010
    To be precise, Check the make and model of your Network card. PS. Now that you have already lost the driver, you may need to open up the machine to see the make and model.
  • Celenous May 11, 2010
    Please provide make and model of your machine and or components so that we can direct you to the approprate drivers for your machine.
  • 58 Answers
You can install the network drivres through *********** board installation CD if you have the built in LAN card.
Hope this helps.
Posted on Feb 02, 2009
Phone not showing network connnection
The repair process probably didn't do the trick. Have you tried resetting the TCP/IPstack, applying winsock and/or crypto fixes?
The TCP/IP stack (netshell) can reset manually by simply going back and using the classic command prompt screen.
Hit the Windows Logo Key, if your keyboard has it, and then alternately press the R key.
OR
Simply go to Start -> Run
THEN
Type in the given text field: cmd
Press Enter key or click OK/Run.
A black screen with a blinking cursor and some nifty white text should appear (should bring back some memories!). Go ahead and type in the following, EXACT:
netsh int ip reset resetlog.txt
Go ahead and press the Enter key when your finished typing this out.
It should just execute, and when complete, go ahead and exit out of the command prompt window. Finally, go ahead and if you haven't already, run the winsock fix (it supposedly does the netsh fix in this tool, but we did it just in case!), which can be downloaded on line through a simple google search. Then reboot your machine. See if this does it, if not, try the crypto fix. It usually works to machines that have a hard time updating through MS windows update website, but i've seen this fix work miracles for networking issues.
If all else fails I would try three things...
1) Re-install the LATEST driver for your network card. If nothing happens STILL, pop another one in a PCI expansion slot, and see if this is detected and installed properly by windows XP. It's preferable you use a standard PCI 10/100 Intel PRO LAN card or something by Linksys, since Windows should have stable generic drivers for most of these cards. If you can see the expansion card in network connections as a Local Area Connection, I would say that your integrated LAN MIGHT be defective, but I doubt this.
2) Do a complete OS restore. This means basically to back up all your data that you absolutely need, and perform a full Windows XP installation from scratch. Boot to the CD, make sure you format your hard drive, use the full format if you want to write zeroes to the drive, guaranteeing that all your previous data will be gone, and then reinstall XP through the Windows XP setup screen. Sometimes these windows repair sessions don't do the trick... they copy over usually just the essentials, like DLLs, popular EXE files, etc.
3) Apply or Reinstall Windows XP Service Pack 2. This usually fixes errors such as corrupted Windows Firewall/Security Center, and it may fix your network connections service. IDK which service it is in Windows XP, i think its the Network Connections service? Go ahead and check to see if its running, or if its even there (think administrative tools in control panel).
Still want more help? PM me or just re-post with your progress, and good luck!!
Increase Engine Horsepower.
May 31, 2012 | Samsung Infuse 4G Smartphone
My local area network doesnt wrk. ethernet & network cntroller are missing
Please download and install the following (Windows XP)
Acer Aspire 5610 LAN Driver Download
Navigate to your Network Settings under control panels. Make sure your network adapter is not disabled.
May 22, 2010 | Acer Aspire 5610 Notebook
My xp network card is not working some reason plz
There can be a problem with the local area connection, the driver, or it's just the network card that it doesn't work, for this i'll need to see what kind of windows do you have and try to disable and re-enable the local area connection (LAN).
After you do that try to see if it works, if it doesn't try to uninstall the card and re-install it, but to give you the instructions i'll need to know what kind of windows do you have...
Apr 27, 2010 | HP Compaq Presario C700T
Internet connection setting for Belkin N wirelss modem router
If you can connect to the internet without the connection icon in the system tray, I think its fine. But if you really want to see the blinking icon, go to start>control panel>netweok and internet connection>network connection. There you can see the local area network icon. Right click on it and then properties. A new window will appear, make sure the "show icon in notification area when connected" is checked. Thank you and good day.
Apr 25, 2010 | Belkin (F5D8231-4) Wireless Router...
Lenovo t61 laptop has no tcpip communication ran the "system health" test in Lenovo PC doctor 5 for windows. os XP pro service pack 2 ethernet card has both lights operating showing conection to network...
A couple of things need to be done.
Install SP3 this is the latest service pack for XP.
Install the TCP/IP (Internet protocol)
Open Control Panel - Network Connections - right click on Local Area Connection - click on the box for Internet Protocol (TCP/IP) and the click on Install.
Then reboot the computer.
You network should now work.
Nov 29, 2009 | IBM Lenovo ThinkPad T61 Notebook
Vista cannot discover XP hosts
This happens if Vista retains history of network devices that once existed on your machine, but do not exist anymore.
Follow the steps at the link below for solution to your problem:
http://techs4u.wordpress.com/2009/08/04/windows-vista-network-connection-cannot-be-renamed/
Jul 30, 2009 | Microsoft Windows Vista Business Edition...
Windows XP uses 100% of ethernet connection for no reason
Download HiJacktThis from here
http://download.cnet.com/Trend-Micro-HijackThis/3000-8022_4-10227353.html
Save report and email to me at pippincp@msn.com
Jun 19, 2009 | Microsoft Windows XP Professional With...
I have a Dell D600 and I cannot install Windows XP on it
Format your machine to its orignial OS (XP Home). There are some limitations that some of machine wont able to carry. The XP Professional might not compatible with your machine. That's why you encouter hang-up from your machine.
Apr 05, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Dec 02, 2008 | Computers & Internet
No connectivity after.....
If you have installed Windows XP Service Pack 2 and are experiencing any of the following symptoms, this bug is affecting your system.
After installing Windows XP SP2, your network connection reports a problem with "Limited or No Connectivity"
You have trouble connecting to the Internet or your local area network after installing Windows XP Service Pack 2.
Your network connection gets stuck "Acquiring IP Address"
Oct 18, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
