Question about Gestetner DSm615 Digital Imaging System
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
    Sniper:
  • 86 Answers
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Good luck and please rate me, thanks.
Posted on Feb 03, 2009
SC:500
At the back, replace the main motor.
Feb 28, 2014 | Gestetner DSM615 Black Toner Cartridge...
How to clear error code SC302, Dsm615 nashuatec
Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
To RESET it
1. Press Yellow button
2. Press 1, 0, 7
3. Hold Orange button for 3 seconds
4. Select MODE 5
5. Select Clear Memory (or something like it) (801)
6. Select 002-Engine
7. Select EXECUTE
8. Turn the switch off and leave it for a minute
9. Turn back machine On.
10. Done, or else there could possibly something else.
Good Luck....
Thanks for using Fixya.
Mar 04, 2013 | Office Equipment & Supplies
What is the repair code of nashuatec dsm615?
please tell me what is your code in this machine -thanks
Dec 22, 2010 | Gestetner DSm615 Digital Imaging System
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Error sc:544
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
Oct 09, 2010 | Gestetner DSm615 Digital Imaging System
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
Jan 20, 2009 | Gestetner DSm615 Digital Imaging System
475 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
