Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
Smeg A2A all the Gas burners turn off intermittently
Hi Can you help the gas hob on our range cooker turns its self off
all burners do this but some are worse than others is there a part from smeg that controls the flow or ignition ?
I know a corgi reg guy but some ideas of this fault would be good
  • 112 Answers
I think it`s got a regulator at the back where it connects to the gas.
Get it checked for the correct pressure.
Posted on Feb 02, 2009
How to lift a2 smeg cooker hob
remove cast iron pot stands and pull off all knobs and small timer buttons. lower the oven doors and look up under the panel holding the knobs and you'll see a screw at each end, remove them. you can now remove the stainless switch panel, (swing the bottom out first) you can now get access to screws at each top corner which should be removed. you can now lift the top panel of the cooker by about 5 inches when a pivoted stay should drop down each side to allow you to rest the top in an open position.
Oct 13, 2012 | Smeg A2.5 Dual Fuel (Electric and Gas)...
How do i change the volume on the oven timer? i
whilst alarm is ringing press the minus (-) button. there are 3 volumes to choose.
Jun 06, 2010 | Smeg Kitchen Ranges
Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
Oct 07, 2009 | Stoves 1000DFDL Dual Fuel (Electric and...
Gas hob turning bottom of pots black..not sure if the hob is installed properly
if the hob is turning the pots black the cooker needs a good cleaning they have air ports in the burner assembly they could be blocked or the incoming gas preasure to too high and needs to be checked by a gas engineer
Aug 19, 2009 | Cooktops
Gas hob is very difficult to start. have to hold
I've just had this prob on an inherited (just moved into new house) A2. Thought I was losing the plot as followed instructions to the letter re starting gas hobs. Got an engineer in to give the ecking thing a general service & told him about the hob. He said I wasn't pressing the knob hard enough. If you press the knob enough to make the ignition click, press the knob a bit further (it will go a bit further "in" honest). If you do that it should start like a good 'un (I felt sooo daft). Something to do with magnets!! Anyway, give it a try (this works for me unfortunately I've had the damn inner glass on the main oven go pop - yes, infront of an engineer twice in less than ten days. Knobs aside, I'm starting to go off this cooker. I want to cook to eat not have a "pretty" in the kitchen!).
Apr 12, 2009 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Installing Smeg Gas Hob PGF75-3 Ultra Low Profile.
yes u can install it at the top of the drawers but check the gas connection before closing the drawers to make sure ther no problem,the inlet gas connection is in rigth side facing to u.
Nov 28, 2008 | Smeg Cooktops
COOKER HOSE
It is illegal to fit a cooker to a gas connection unless you are a registered Gas Safe Engineer . You can find one in your area if you visit www.GasSafeRegister.co.uk
or ring freephone 0800 408 5500
Jun 09, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Smeg gas hob issues.
Ghazwan,
Relax. The problem is in the switch that is activated when you turn the gas on. It has either misaligned or broken. The gas itself is not involved. Generally, raising the top of the burner area will gain access to the switch and valve. Inspect and readjust or replace. Oh, and disconnect the electricity before touching the switch itself.
Mar 06, 2008 | Kitchen Ranges
Low Gas Pressure on Smeg Range cooker
there should be a regulator on back of the stove where the gas line connects.you will see a plug that unscrews,remove this plug and run the unit.if this solves your problem clean the plug really good and put back on.
Dec 25, 2007 | Kitchen Ranges
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
478 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
