Question about Samsung SCX-4216F All-In-One Laser Printer
Paper getting stuck in the printer
When we try to print number of copies ,we face the above mentioned problem.What do we do?
    New Friend:
  • 159 Answers
You have problem in paper out roller and pickup roller tray to clean the roller or replace it if need
Posted on Feb 02, 2009
When u make a copy the paper come out blank
if its a inkjet printer it may be cartridge dried if ur not taking print out once in a week you may face this problem also u have not mention the model here
Mar 21, 2015 | Office Equipment & Supplies
My Canon MP480 says the paper is jammed when in fact it is not. how can i reset it?
Turn off the printer.
Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it
Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance or repair.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Mar 04, 2014 | Canon Pixma MP480 All-In-One InkJet...
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
When I try to line tells me that the paper size mismatch and only takes a copy of the text
Have/had the same problem: Getting "paper size mismatch" on the C4280 status screen, after we got a paper jam. Every time we hit OK and put in paper, Message about "Now printing Alignment page", it feeds through quickly, with nothing printed on the page and reverts back to Paper size mismatch. Finally got rid of the error, not sure how, but now when I try to copy anything, we only get the lower right postion of the document that I'm trying to copy. Printing from the PC seems ok.
Powered off and back on, and it is back to P"now printing alignment page, quick feed through and "paper size mismatch" error. AND
When copying directly from the glass panel,it will only print a quarter of the page -however it prints and coorectly if we print directly from the computer.
The problem is the paper size sensors. Remove the plastic access panel that is for access to the rollers in the back and has 4 rollers on it. There are two papaer sensors attached to the printer circuit board (PCB). The control arm for the sensor is a small plastic piece that extends slightly into the paper path above the PCB. The plastic can be broken when you are removing a paper jam. I stuck a small piece of a match stick in the sensor to keep it open (as though a wider piece of paper was passing throught the printer). I can't switch to smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until after it does the alignment phase.
Dec 16, 2010 | HP PhotoSmart C4280 Laser Printer
In faxing how do i place the printed side into the fax slot?
Should be a drawing on the paper tray, most go face down. Try a copy first to see which side copies and which side gives blanks.
Jan 05, 2010 | HP Officejet 4215v All-in-One Printer
Canon MP470: paper stuck
Unfortunately you need to disassembly the hole printer to solve the problem.In most case the object who block the paper is under the withe rollers and you can't see it from above.
Oct 12, 2009 | Canon PIXMA MP470 All-in-One Printer
When I try to print to my laser printer MF4150, it prints one copy and the error light comes on and ithas LOAD CORRECT PAPER CASSETTE :A4 I pulled the paper out and reloaded. I Looked in my BASIC GUIDE...
Go in (win xp)
control panel
printers and fax
right click on the printer giving problems
click on properties (down the list)
click on printing preferences
on page size, switch from A4 to letter
click OK
Have a nice day
May 01, 2008 | Olympus P-11 Thermal Photo Printer
Paper jammed
I had exactly the same problem, printer virtually new, printed great for a couple of weeks, then today refused to take paper with E3 flashing. No apparent blockage - all looked clean, tried all the utilities, roller cleaning and plate cleaning, but wouldn't take paper!
Solved it by moving the paper size guide all the way to the left, then folding the top 20mm of a sheet of A4 over and loading it so fold is at the top facing you. This acts as a catcher for anything stuck in the printer. Hold the paper slightly crooked with the left side slightly further into the printer and press the copy button (with nothing in the scanner!). It should draw the paper in now (with some persuasion) and think it is printing (it's blank,of course). Check as the top of the sheet goes in that the fold is still tight and doesn't open up as it feeds in. Lo and behold, mine brought out a 5p piece - printer now prints perfectly!
Mar 20, 2008 | HP LaserJet 2100 Printer
Paper stuck under printheads
I dont think the paper is beneath the ph. Some paper will stuck between the gear wheels. Pull papertray out and try to look from the bottom into the printer. Another way is to have a close look at the even left and right side from above when you open the scanner (like changing the carts).
Nov 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Samsung SCX-4216F All-In-One Laser Printer Logo
103 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
CheckitRight
CheckitRight
Paul King
Paul King
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
