Question about Pioneer DEH-1600 CD Player
Cant play cd or eject cd from my pioneer deh-1650 car stereo
I have a cd in the head unit which had been playing, and now wont play at all, and cant even remove it.
normally would push the src button to switch between radio and cd player but now wont work at all.
this button will still turn stereo on and off but wont goto cd at all.
was wondering if there is a reset or how can remove cd and get cd player to work again??
head unit is actually the pioneer deh-1650
thanks very much if you can help.
  • 328 Answers
SOURCE: ipod worked with my pioneer deh-p3700mp before
this works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Posted on Dec 31, 2008
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
dj x
  • 61 Answers
SOURCE: Pioneer DEH-2150 : CD Ejection switches off the Stereo
hi rolls
when there is no CD in unit hold the source button to turn unit to actual on position (when you insert a CD is it self guided once you push it to a certain point or does it just self guide instantly) if you sort of push it in a bit and unit turns on its because the pioneer function says to itself i need to be on so it will play for you but once you eject the CD the unit says time to turn off the solution i recommended should solve this if not let me know and ill figure out another step
hope i was able to help
Posted on Mar 05, 2009
SOURCE: HOW DO YOU CHANGE THE TIME ON A DEH-P59001B PIONEER STEREO
Its not the select button, you must have the power off and hold the function button down for about 5 seconds, display will change and you will be able to navigate your way to the clock from there. Hope this helps.
Posted on May 27, 2009
  • 3 Answers
SOURCE: I installed a pioneer Deh p49001b car stereo in a
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
Posted on Aug 12, 2009
My Pioneer DEH-P3500 car stereo is having problems. The front panel buttons will not work at all... the radio was working, but the head unit would not let me change stations or make any adjustments. I...
if its under warranty just return that on the store or in the authorized service center.if not just bring that on your local repair shop. because there is no serviceable parts inside the unit. ty
Jun 21, 2011 | Pioneer DEH-P3500 CD Player
It was working fine I shut the power off and just had the radio playing then turned it off for a few minutes and the car wouldnt start so I had to get a jump now my radio wont work its a pioneer...
Check the fuse panel under your dash, & there may be a fuseable link in the ignition wire behind the stereo also, somtimes when you get a jump it can pop a fuse or 2.
Feb 26, 2011 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Hooking sat to car stereo
that plug at the back is not for sat radio. It is for use with steering wheel controls. You have the blue plug at rear of stereo and that is the plug for sat radio. Ericson electronics is contracted to build the sat compatible units that wire into this radio through the blue. plug. if you are using 3.5 plug audio control from a portable sat receiver, the you will need to buy an aux input cable for your stereo..
Sep 25, 2009 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
Pioneer DEH-10 won't play cds
the cuircuit board on the cd drive is bad faulty. this is why the lens wont and can't read the info on the cd
Jul 07, 2009 | Pioneer DEH-1100 CD Player
My Pioneer DEH-P835R Cd Player will play my cd but wont eject
Check in the front and you should see a small hole thats about the same diameter as a paper clip. Open up a paperclip to a straight 2 inches and poke it through the hole. It should release the door so you can get it open or at least seat the cd if thats whats making it not open.
Apr 26, 2009 | Pioneer DEH-P835R CD Changer
Pioneer deh-p3950mp unit plays disc but won't eject or respond to any other commands except volume. any ideas anyone
Just follow this link for manual
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players/DEH-P4950MP?tab=D
Mar 01, 2009 | Pioneer DEH-P2900MP CD Receiver...
hi rolls
Feb 14, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Disc stuck in deh-p7000r plays but wont eject
should be a small pin hole next to the disk tray, 2 or 3mm wide. Insert a pin and that should then cause the disk to be ejected.
Aug 25, 2017 | Pioneer DEH-P7000r
Pioneer DEH-p3700MP Head unit and CD stuck
Had the same problem with a burned CD with a printed label.
I had to press the eject button and help it with some plyers.
Best of Luck.
Nov 27, 2007 | Pioneer CD Receiver - DEH-P3700MP - CD/MP3...
Pioneer DEH-1600 CD Player Logo
269 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
