Question about Itech Clip IIe Wireless Headset
Pairing I have bought this devise and cant seem to pair it with either of my phones? Any sugestions?
  • keiden_dall Feb 02, 2009
    Thanks for that but still no joy, any other sugestions?
  • keiden_dall Feb 05, 2009
    Hi there
    Basicly if i turn the devise on and the led show it is active, i try and serch it with my htc and it can not find it, i tryed with my parteners nokia and still no joy,
    Any sugestions?
Press and hold the button (on/off button) on the ear piece until the light becomes blinking blue and red. Turn on the bluetooth scanner of your phone and search. Select the handsfree and pair them. Simple.
If you turn on your handsfree and the light is blinking purple, that means you need to turn off the handsfree and restart with holding on to the button on the ear piece.
Posted on Sep 02, 2009
  • 679 Answers
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select Clip lle once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Feb 02, 2009
  • rockfixya
    rockfixya Feb 02, 2009
    please explain your problem, so i assist you as long.
    Thnaks
What is the pairing code?
The pairing code is a sort of a password that only the primary sender will have on their devise and this code in turn reflects unto the secondary receiver. Failure to insert this code within few seconds the devise will fail pairing and you have to start over again, switching bT on and off again.
Feb 12, 2014 | Itech i.Tech i.Oval 303 Bluetooth Headset
I cant pair my phone with bluetooth it keeps sayn no devces found
continously press the power button on the headset for 2 seconds and then try to search from the mobile
Mar 15, 2011 | Jabra BT350 Bluetooth Headset Headset
I have tried pairing my second phone which is a verizon lg vx9200 and it keeps telling me pairing failed. I have entered passcode 0000 and it keeps telling me pairing failed. any sugestions
some bluetooth products will only pair with one thing at a time. if you are actually swapping for another phone it may help to delete the original paired phone...hope this helps
Oct 09, 2010 | Blueant Supertooth 3
I just bought a samsung soltice phone and I have a scala-600 bluetooth but I cant seem to get them to connect have any suggestions and I have used a bluetooth befor.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 12, 2010 | Cell Phones
How do i reset this devise to resync with my phone again?
Press and hold the power-on button for 10 seconds or until the LED starts blinking. The headset is now in "Pairing Mode" or "Discoverable" and you can pair with your phone.
Jan 23, 2010 | Plantronics Explorer 230 Bluetooth Headset
How to pair my moby to visrolite
1.from off - press and hold the accept button - green button
2.while holding the accept button switch on - press and release microphone
3.when bluetooth indicator turns blinking red/blue, release the accept button.
The kit is now in pairing mode.
4.while in pairing mode access phone and search for devices.
5.when the phone displays list of bluetooth devises select visorlite
6.when the phone asks for the password enter 0000 and OK.
Oct 18, 2009 | Computers & Internet
BlueAnt Supertooth Light wll not connect to apple iphone When I switched to a iphone 3gs it will recognize the devise but when I place the code in which is ''0000'' it says the pin in invalid.
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 08, 2009 | Blueant Supertooth Light Bluetooth...
I Cant seems to pail motorola h700 headset to samsung g600
Well, it sounds to me like you know how to get the headset in pairing mode, have you tried turning off your old e900 and then pairing?
This guide was taken from here.
In standby mode, press Menu. Highlight Applications and click Select.
Highlight Bluetooth and click Select, or just press 4.
Highlight My devices and click Select, or just press 2.
Put your remote device into pairing mode. You can find out how to do this from the manual that came with the device. When the device is in pairing mode, highlight Search new device and click Select.
If Bluetooth is not activated on your G600, you'll be prompted to switch it on. Click Yes.
The G600 will search for all the Bluetooth devices in the proximity. The type of device will be indicated by the icon to the left of it, so you can clearly see if the device is a PC, a phone or a remote headset.
You'll be asked to enter the PIN number to connect to the device. This is in the documentation that came with the remote device but if in doubt, try 1234 or 0000, as these are the most common PINs.
Once connected, the device's icon will turn orange on the My devices screen, and when you press the red End call key to return to standby mode, you'll see the headphone icon on the top row of the screen.
Your headset will now be paired permanently with your G600. Switch the device off to disconnect it, and next time you switch it on the phone will connect automatically, providing your Blueooth is activated (go to Menu, Applications, Bluetooth, Activation, On to activate Bluetooth).
My apologies for the copy past guide, I have never used a samsung phone.
Dec 25, 2008 | Motorola Mobility H700 Wireless Headset
Bluetooth pairing Nokia N95 with Toshba Satellite
btooth has several stages
search
authentication
pairing
coneect etc..........
passcode is required in authentication
it is very simply
the passcode can any natural number
the same that u use in the first device should be use in the second devise when asked.
if you type 1 on first device .
the same 1 should typed on the second device
this is for your security. that u r connecting with the required device
Dec 14, 2008 | Nokia N95 Cellular Phone
Security code to pairing my nokia 6126 to my bluetooth devise
if you haven't changed it just type 12345 or until you have to fill up the box
Sep 21, 2008 | Nokia 6126 Cellular Phone
Itech Clip IIe Wireless Headset Logo
780 people viewed this question
Top Itech Radio Communications Experts
Vernon Taylor
Tom Chichester
Are you an Itech Radio Communication Expert? Answer questions, earn points and help others
