The washing machine does not spin.
The washing machine is equiped with a "Spin motor" that dissengauge the clutch when it is on a spin cycle by pulling a cable that is attached to the clutch. I have dissasembled the motor which consists of a number of plastic gears and it worked for a few days after I put it back but stopped working again. I am sruggeling to get spares for the washing machine as it is 9 years old. Is there something else i can replace the spin motor with? Perhaps a solenoid of some sort.
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Motor on wash cycle does not spim
??? wash cycle is not suppose to spin only agitate, most machine have a dual motor function, motor runs in 1 direction for wash then in another direction for spin. do u mean it does not go into spin? if so need to check the tranny and the clutch, the motor coupler in some cases and if its not agitating washing may have bad cam dogs in agitator, or bad water pressure switch, some times a bad door switch will not allow spin or agitation?
Sep 27, 2014 | Whirlpool Cabrio WTW6200VW 4.5 Cu. Ft. Top...
WASHER WILL WASH ON ALL CYCLES, BUT WILL NOT DRAIN OR SPIN ON EITHER CYCLE
If the timer advances normally thru the spin and drain steps of the cycle you selected, than the problem that would cause neither spinning or draining, is the wash motor is not reversing. The motors is a two direction motor. It spins clockwise for normal agitation, but counterclockwise to engage the wash drum clutch and operate the drain pump. I would ask you to check for motor sounds at all during the spin and drain cycles. The pump reversing in the spin or drain cycles can be a function of the machine's lid safety switch, or if not the motor switch or timer contacts. The lid switch is first thing to check here, for sure! If the machine seems to stop running when it comes time to drain or spin, the lid switch is your best bet!
Hope this helps.
kcomp1863
Jan 16, 2011 | Roper RAS8445KQ Top Load Washer
Spin cycle does not operate
Your clutch on your motor is not working. Your clutch on your motor controls how the motor either spins or agitate.
Dec 15, 2009 | Bosch Washing Machines
Spin cycle begins, basket rolls, slipping....
if you can open the front of the machine
inspect the motor and clutch area
clutch is under motor
Oct 09, 2009 | GE WDSR2080D Top Load Washer
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
Washer doesn't spin
Hello skull1829 ,
Was the Clutch/One-way roller bearing changed out for dc/UC errors in your FAV6800AW/FAV9800AW?
If you start a Spin Only Cycle with an empty wash basket will the wash basket spin up CCW and complete the cycle? Lift the washer top from the base a few inches to observe the wash basket CCW rotation in spin cycle. If the clutch spring is broken or end pins of spring aren't seated the tumblers will rotate and the wash basket will rotate slowly CCW.
IF the wash basket won't spin up can you pull the front cover off and insure the motor will rotate the clutch pulley CCW in a Spin Only Cycle? Let’s try these few basic tests and get some feedback for troubleshooting.
Rich
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Wwsr3090t8ww
It's possible that the high speed windings on the motor no longer work, or it could be the clutch.
If the motor is spinning very fast, but the tub is not spinning, then the clutch is broken. If the motor is not spinning fast, then it probably needs a new motor.
Sep 06, 2008 | GE Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
