Swing with Jdbac Odbc & choice,list
I have a problem in my source code .I m doing my project in "hotel management system" in swing,jdbc odbc.
OUTPUT is---
Customer No. :(Text Field)
Contact No :(----//-------)
No. Of Member:(choice or List )
//here I have problem Because I cant add funtion stateItemChaneged it give eeror,Kindly help me by giving the Source code of the above program.
  • 115 Answers
Epson PLQ20 Passbook printer Problem:"comunication Error"
Hi, Check your cable connection. Check for updates from Epson. Restart your computer . Good luck.
Jun 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
Please give me the procedure how to import foxpro files in tally 7.2
To import data from a FoxPro database, use the Microsoft Visual FoxPro ODBC driver. To do so, follow these steps:
1) Click Start, and then click Control Panel.
2) In Control Panel, double-click Administrative Tools.
3) In the Administrative Tools window, double-click Data Sources (ODBC), and then add a new ODBC data source for your FoxPro database or tables by selecting the appropriate Visual FoxPro driver.
4) Start Access, and then open your Access database. 5) On the File menu, point to Get External Data, and then click Import. 6) In the Import dialog box, click ODBC Databases in the Files of type list. 7) In the Select Data Source dialog box, click the Visual FoxPro data source that you created in step 3, and then click OK. 8) In the Import Objects dialog box, click the tables that you want to import, and then click OK.
Jul 05, 2010 | Computers & Internet
I have to make minor project on java and i know core java and jdbc odbc connectivity will u please help me
It would probably be wise to post this on a Java forum (like this one, this one, or this one), as they will be able to help you better.
Alternatively, try Stack Overflow.
Feb 19, 2010 | Microsoft Windows XP Professional
How to link vb 6.0 to msaccess?
You Need ODBC to solve your link... ODBC is a gateway. Can Access by Microsoft Access or VB in same time... Note: Please in Code Programming you must lock or unlock you data if you want application running same time..
Jul 20, 2009 | Microsoft Computers & Internet
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
thanks
Kuldeep
Mar 13, 2009 | HP Computers & Internet
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
What is use of Jdbc or odbc driver?
Go through these links to get an overview of JDBC and ODBC:
http://en.wikipedia.org/wiki/Java_Database_Connectivity
http://en.wikipedia.org/wiki/Open_Database_Connectivity
Jan 17, 2009 | Computers & Internet
How can i connect jdbc odbc to do my program
Create a System DSN in Windows XP loadTOCNode(2, 'summary');
  1. Click Start, point to Control Panel, double-click Administrative Tools, and then double-click Data Sources(ODBC).
  2. Click the System DSN tab, and then click Add.
  3. Click the database driver that corresponds with the database type to which you are connecting, and then click Finish.
  4. Type the data source name. Make sure that you choose a name that you can remember. You will need to use this name later.
  5. Click Select.
  6. Click the correct database, and then click OK.
  7. Click OK, and then click OK.
Jan 14, 2009 | Microsoft Office Professional 2007 Full...
ODBC DRIVER MANAGER FOR RUN TIME ERROR 2147467259
Go to Administrative Tools, Data Sources (ODBC). Check your connection info and test the connection manually there. You may have the wrong user/password combination, or the database name or location is wrong.
Jul 10, 2008 | Microsoft Windows XP Professional With...
How to configure odbc for multiple user in windows 2003 server
You can also try adding the datasource as a System DSN instead of a User DSN. Of course, all users on a given system will then have access.
Apr 03, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
