Question about Tally T6215 Matrix Printer
My tally printer T6215 HAS A CPU LOST PROBLEM
    New Friend:
  • 114 Answers
The problem comming from the power supply of your printer. Check the power supply.
Posted on Feb 02, 2009
Tally t6215 page break
It is probably not the printer problem . First confirm it by taking 2-3 windows test pages . If it is coming properly than your problem is surely form the package you are using. Ask the system administrator to rectify the problem from the software . page length and printer emulation must be added in the software.
Jan 10, 2013 | Tally T6215 Matrix Printer
I have a Tally 6212. I'm using non Tally ribbons which is producing a ribbon fault. I'm told by my ribbon supplier that there is an override to keep the ribbon from causing the fault. Can you...
If the ribbon is causing the Ribbon Fault, they would not be very well made compatables I would suggest changing to one of the other brands available. I belive the T6215 senses the ribbon turning by having a silver strip stuck on a rotating disk on the back of the ribbon, if this strip is not present or is not being detected it will display a Ribbon Fault. You can check the ribbon to ensure it has a reflective strip by manually winding the ribbon and looking at the back side of the ribbon, you should see a rotating disk which is half silver and half black. If this disk is not present the compatable ribbons would not be that compatable. The T6215 does to have a fault over ride for the Ribbon Sensor on its own, you can only over ride all faults this may cause other problems as Paper Out, Paper Motion errors are also overridden. You can enable fault override in the following way; Press and hold down LINE FEED and ENTER for about 5 seconds untill the printer bleeps. Press and Hold down FORM FEED and ENTER for about 5 seconds untill the printer bleeps. The above actions enabls Fault Over rides temporarily if the printer is powered off or reset Thai setting will be lost.
Apr 21, 2011 | Tally T6215 Matrix Printer
Tally t6215 is printing continuously, one line a page. how do i make it print normally?
I would suspect this is happening because the system printing to the T6215 is sending only Line Feed Commands and not Carriage Returns. Access the menu on the T6215 and enable the AUTO CR function. This will cause the printer to append a Carriage Return each time it sees a Line Feed, this should resolve the issue.
Dec 22, 2010 | Tally T6215 Matrix Printer
Tally T6215 does not power up
There is two reason behind the problem (1)Power Supply . (2) logic Board. At first check the power supply if the power supply is ok then change the logic board.
Jun 12, 2008 | Tally Line Matrix T6215 Printer
Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
May 01, 2007 | Tally T6215 Matrix Printer
Paper out LED won't go off
i had the some problem. and it was on the position of the sensor, i needed to replace the sensor, because he was pointing to a paper hole, the ones used to pull the paper.
Sep 05, 2006 | Tally T6215 Matrix Printer
Tally T6215 Matrix Printer Logo
262 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
