Question about Dell 3100MP Multimedia Projector
Smd board to board connector rework
We have a problem wiht the rework of SMD connector that connets two board.
While we are reworking that component with normal solder iron one it is easily getting shorted.
So what is the solutionn for that.
The componen p/n is 1450087060930861and it is of Kyocera make.
  • 93 Answers
Try the hako solder rework station,dont ever try an ordinary solderinr.form what u have mentioned , it appears the connector is alrady short.suggest you to rmeove the connector with hako or similar solder rework station & if the connector isnot damaged during rework, resolder using the same station or buy a new connector.this hsould solve ur prob
Posted on Feb 09, 2009
Why does the screen turn white after 10 minutes?
Probably the t con board have problem. the power regulator ic on the tcon board make this problem. As ist an smd ic you have to go for a new tcon board, because its not possible to replace the ic with normal soldering irons. you need smd rework station for that purpose. And also on more thing in some tvs the t con board is integrated to the lcd panel. if so its not possible to replace only the t con board , you have go for a fresh lcd panel. it would be a costly repair. because the panel is the costliest part of the tv. Any why check the video to understand which one is the t con board. if you find one in yours then try to replace it with new one. hope your problem will solved
www.electro-medical.blogspot.com
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 03, 2015 | Samsung Televison & Video
Soldering iron and rework station
NEW Updated Aoyue 968A SMD Digital Hot Air Rework Station 4 in 1...
There are many rework stations on the market, and the price range is from a few hundred to a few thousand dollars. So it's a matter of your needs and budget.
I suggest you go on line and do a search " soldering rework stations" , and read up on the various models that are available. Amazon is a good site for this, because you can get a lot feedback from people who purchased the products.
Jun 02, 2014 | Fuji Instax 210 Wide Polaroid Camera 80...
Westinghouse model SK-26H570D sound went out
First of check the speakers the tv. If its ok then the problem is with the audio output ic in the main board. Its an smd is to replace the same you need Smd rework sation. Its better to contact the nearest servcing center. Or you can replace the main board to sove the problem. I have adds a link which will lead you the main board for your tv. confirm the image with the main board in your tv before purchase.
Main board
Ajin
Mar 31, 2012 | Westinghouse Televison & Video
My question is why the Sony when I switched on with a cd inside, it show me reading and a few seconds after ,it will turn off displays PROTECT
hi,
You have to check your system after removing all the speaker. If it shows protection then also then any one the audio outpout ic insid the player is faulty. If it work without showing protection then there will be some problem with the speaker.you hve to find out which speaker is faulty by conneting one by one. If the output ic of the system is faulty then you have to consult some electronic repiaring shope. Because to replace there ics you need SMD rework soldering station. All the audio output ics in your palyer is SMD (surface ***** device). Also need a good skill in electronics to replace these SMD ics
ok
Aug 06, 2011 | Sony DAV-FC9 System
Why does my system say protect when i turn it on?
Possible that the output section is SHORTED and so the power is cut off to protect from further damage. This is due to the fact that the stage consumes more current than requried due to a damaged component. So check the output drivers/IC, remove the speakers and check in case the speakers are damaged.
Feb 10, 2011 | Samsung HT-Z310T Theater System
Hello i have a sony dav-1s10 and it wont start it say protector
hi,
Any one of the output amplifier IC( integrated circuit) of ur sony have some problem. sony has an output protection circuit to protect ur speakers when the output ic become faulty. it will come to normal operation only after replacing the faulty component. normally sony uses SMD (surfase ***** dvices) ic.for replacing the same u need SMD rework station. better u consult the manufacturer
ok
Dec 30, 2010 | Sony DAV-IS10 System
Hp nx6110 laptop keeps hanging but works well when pressed on top of touch pad or hard drive.
Only if you have knowledge on hardware Laptops you understand. The procedure go as follow:
Unscrew the motherboard completely.
Identify the North-Bridge BGA IC (BGA= ball grid arrays) under the mouse region.
Get an SMD Rework Station.
Suspend the board on a surface which cannot be affected by heat and held firmly whereby under the North-Bridge BGA IC is opened.
Use your SMD Rework Station to generate heat  evenly beneath the region North Bridge IC and press gently without being bridged.
Mind you 90% risk is involve.
Oct 07, 2009 | HP Compaq nx6110 PC Laptop
Dropped in bowl of water
Use hotgun (SMD rework station) to re-hot your all chips in your circuit board
Jul 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
When i turn on the camera/vidoe the screen stays white and i cant do or see anything
Hi there, if all files from camcorder load to your computer and you can see all yours pictures, problem can be in display cable via damage wires. Besides the reason can be a crack in the screen or damage of electronics components SMD.
Display - mobile part and connect to camcorder bunch from 21 of the flex isolated wire. At use is always bent and once breaks. Of enough breakage of one wire and screen will not show. To define it it is not difficult, but is necessary for this purpose the complete disassembly camcorder, besides it is necessary to have spare wire connector. The repair of devices on SMD components is carried out through special equipment of the soldering, special oils and fluids, SMD rework station and microscope for assembly. Sorry, but if you not make it, never begin. Cheers.
Sep 24, 2008 | Mustek DV520T Digital Camera
Dell 3100MP Multimedia Projector Logo
351 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
