Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Timer switch has broken on bosch wvf 2401 how to replace?
My timer switch is broken on my bosch model wvf 2401. I have a new one but not sure how to get the old one off and get the new one on. CAN ANYONE HELP?
  • Anonymous Apr 04, 2009
    I have exactly the same problem, only I don't even have the new switch! Where can I get one from?
First remove screws X2 from back of the machine that hold the top cover on. Once removed the whole top slides backwards and can then be lifted off. This gives you access to the plastic clips that hold the timer face panel on. The main control dial must first be pulled off through the front cover, then remove the front cover by unclipping it (a pain and a fiddle!) The dial on the timer can then be pulled off revealing the two mounting screws that hold the timer in!!
Posted on Apr 06, 2009
I have the same problem, where i can buy switch and i dont understand last answer. Please can you giv us more explanation. Sorry about my englsh
Posted on Oct 25, 2014
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Bosch wvf 2401
Could be the Pump leaking , it feeds the dirty water out of the washer and is located under the washer close to where the outlet is . Usually a cheap part to replace .
Jun 28, 2012 | Bosch Washing Machines
Bosch wvf 2401
What is your question?
Mar 02, 2011 | Washing Machines
I have a Bosch washer model WFK 2401 and I need a new pressure switch. The repair company I'm dealing with says that they can't get the part from Bosch any longer. Do you have any suggestions for...
We own a Bosch- probably nearly 20 years old. I manged to get the parts I needed- but we live in France and I buy on-line from the UK!
I would go onto the Bosch site. You will probably find spares suppliers from which to inquire. Also I'm sure you could query the Bosch site directly.
I'm not criticizing your repair company but I will be very surprised if the part was not available from somewhere.
Good luck,
John C
Feb 09, 2011 | Bosch WFK 2401
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Bosch washer wont drain wvf 2401
You need to locate and clean the pump filter, usually found at the bottom right front of washer, sometimes behind a removeable plastic cover at the bottom.
Please rate my solution.
Thanks.
Nov 20, 2009 | Bosch Washing Machines
Bosch WFK 2401On/Off Switch
You need a new switch should be able to buy on its own note wiring before doing.. it just pops out i think..good luck
Sep 08, 2009 | Bosch WFK 2401
Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
1,061 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
