Question about Lands Phones
Cable problems in my network a cable connected via computres but these cable some times connect 100mbps and afters few mintes this is disconnected or 10 mbps please slove these problems
  • Carl Navarro
    Carl Navarro May 11, 2010
    Where did the cable come from? Is it a commercial cable, something you made yourself, or maybe it doesn't fit into the jack very well?
  • 79 Answers
You may need to change the wiring if it is very old or faulty. Faulty wiring can slow down the speed.
Posted on Feb 02, 2009
No puedo conectarme con el rauter, no tengo los driver
Hubs don't require drivers. They simply connect via RJ-45 with a Cat network cable.
No necesitas drivers.
Nov 25, 2012 | Encore ENH908-NWY 8-Port 10/100Mbps RJ45...
I am using the Dell Latitude D620, When i am connecting this machine on network I am getting 100 MBPS connectivity, but when i am connecting other machine to the same network port I am getting 1GBPS...
Hi Ajay,
The LAN (wired network) connectivity speed/data rate depends upon the networking hardware (Laptop Ethernet Cards, Switch, Router etc.).
To get 1Gbps connectivity you must have 1Gbps ethernet (LAN) card in the laptops. As Dell Latitude D620 has 1Gbps card, the problem could be with the switch or router, which may be having 100Mbps and 1Gbps ports, depending upon the equipment you are using and it is recommended that you check out the its full specification. If you connect laptop to 100Mbps port you can only get 100Mbps speed. To get full speed, it is required to have 1Gbps support at both ends.
Dont forget to rate the solution if it helps!!
CreativeTECH
Dec 03, 2010 | Dell Ethernet Card Network Adapter
We've got the Dlink DES-1008D setup in our office. Since the past 3 weeks, we've been facing disconnection problems. 5 desktop computers, all new and very recent, are connected to this. We've got an...
Ok, the next time when the disconnection occurs. Try the following:
Open command prompt. And try pinging www.google.com, if the ping is successful and you are still unable to access the internet, then you may want to check the proxy settings on your web broswer, or possibly repair/reinstall the browser. You can also try accessing the internet on a different browser.
If you are unable to ping google successfully, then try to ping the IP address of your wifi modem, this is your default gateway. If you are unable to ping this address successfully, then check the cable from the DES-1008D switch to the wifi modem. As a local area connection 'connected' just shows that the link from your PC to switch is fine.
Please try these steps and let me know the results.
Regards..
Apr 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Low connection speed
Hello, the 100Mbps connection is to your router and not to the Internet. that means you can copy with a speed of 100Mbps(theoretically) between computers in YOUR network. You can test your Internet speed on www.speedtest.net, choose a nearby test point. If you paying for 2mbps and only getting 0.15 I suggest that you contact your Internet Provider because its very low if you paying for 2mbps.
Sep 04, 2009 | Computers & Internet
Network Connect Problem
If your machine is initially connecting then not connecting after some time. I would try the following:
1. Ensure you have a stable connection with your Internet service provider. Check cables and make sure you're not having any power or connection issues with your modem.
2. If this does not seem to be the source of the problem. You may have a problem with malicious software as the connection seems to work initially and then stop. Go to Download.com and download Malwarebyte's Antimalware and scan your machine.
3. If this doesn't solve your problems you may be having hardware issues which may require a replacement of your network card or connected device.
Apr 08, 2009 | Dell Optiplex 755 Minitower Desktop...
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Slow connection w/ FiOS
You may not be interpreting the LED correctly. The Link LED goes on to indicate a physical connection (if the Link LED is out, the cable is damaged or disconnected), but the 10/100 LED only illuminates when there’s a 100Mbps connection. The LED will remain off when the connection is only 10Mbps. Here’s how to quickly determine the speed of your connection. If the 10/100LED is off, there’s a slow connection. If the LED is on, there’s a fast connection.
A fast (100Mbps) network connection requires that both ends of the connection support 100Mbps communication. So, if the 10/100 LED on your hub is dark, chances are that your PC’s network adapter (or NIC [network interface card]) is only operating in the 10Mbps mode. Check the NIC in your Device Manager Network Adapter entry and look for any 10/100 designation. An older 10Mbps NIC may need to be upgraded for 100Mbps operation. If it’s a 10/100 NIC, refer to the PC’s documentation and check the NIC settings to make sure it’s not locked in the 10Mbps mode. Set the NIC to a mixed or 10/100 mode so that it can adapt automatically to establish the best possible connection.
Mar 06, 2008 | Acer Aspire 3004WLCi Notebook
Slow internet
I suspect that the DE-528 (discontinued card by the way) is only a 10 mbps card. Unless you are doing some heavy duty video the card would be fine. Otherwise replace it with a 100 mbps card.
Feb 08, 2008 | D-Link DE-528 Network Adapter
BROADBAND INTERNET CONNECTION PROBLEM (WIRELESS)
Every phone socket must have a working microfilter pluged as shown on the image below.
I think you need to change your microfilters as they might have blown.
microfilter2.gif&usg=afqjcnewmdhgecg08egxbhumf4zmq8g-lq
Hope this helps,
Regards,
Abdul Qayyum
Nov 05, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Handing Problem
You might consider trying to upgrade the BIOS's on the affected switches
Aug 26, 2006 | 3Com SuperStack 3 4228G (3C17304-US)...
Lands Phones Logo
35 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
