Question about Hardware & Accessories
Baxi boiler timer
How do i work the timer on this?? for example to have the heating on from 6am till 9 am do i pull the little bits out or push them in? help!!
  • Anonymous Mar 27, 2014
    Not sure how to set the timer so it will work intermittently during the day and stays off at night 11pm till needed on 3am and then off again till 6am
  • Anonymous Mar 30, 2014
    How to ajust the imer
1)Push all the little pins (bits) inward toward the centre of the dial
2)Set timer to correct time by
turning dial to current time, ie if present time is 4.00 p.m.
Turn the dial until 4.00 p.m is aligned with the arrow symbol
3)PULL OUT all the ( bits) toward the outer edge of the dial to set the time that you want the heating to come on .eg pull out all pins between 6.00am and 9.00am(as each pin represents 15 minutesyou should have 12 pins pushed out)
4) Ensure the3 way switch in the middle of dial is in the middle position(timer) if it is at top position boiler is(constant on)and at bottom positon boiler is turned off.
Posted on Feb 06, 2009
  • simsch Nov 18, 2010
    Thank you a conscise and usefull entry.
I am wanting to wire a Baxi 105E boiler to a Danfoss 102 mechanical timer. The boiler has 5 wires = red, blue, earth, black and yellow. The Timer has six terminals = 1 DHW, 2 HTG, 3 COM, I (earth), 5...
1) Contact baxi:
http://www.baxi.co.uk/contact.htm
2) Which boiler wires? I don't know. Page 24 manual.
Manual says to disconnect link between terminals 1 and 2, and instert timer in-line.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Baxi/Combi%20instant%2080E%20&%20105E.pdf
2) I can tell you about the timer wiring.
Timer is 230Volts
Not sure if you have British Hot-Neutral 230Volt, or Hot-Hot 230Volt.
Wiring is same 2 wires, but words to describe are different.
Let's say you have Hot-Neutral 230V
Connect Hot to L6
Connect Neutral to N5
This will power the timer so it runs and keeps time.
You can get Hot-Neutral wires from Hot-Neutral that arrive to power the boiler.
Now the timer terminals are separate.
E terminal is Earth or ground.
The Common is Hot wire.
The timer then turns on-off and switches back and forth between DHW and HTG.
HTG is heating
DHW is defrost.
Timer has 2 sets contacts.
When timer activates first set of contacts, then DHW defrost terminal receives power from Hot wire on Com terminal. At this time, all power is cut to HTG heating terminal.
When the defrost cycle ends, then the heating circuit receives power, and then the timer has programming that opens and closes a second set of contacts going to HTG heating terminal.
Which wires from boiler connect to each terminal, I am not sure.
Feb 03, 2013 | Hardware & Accessories
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
Oct 27, 2012 | Universal 900MM Super Thermocouple Baxi...
Boiler not working
I would call the person or company who installed it. May be a simple fix you do not know about. You may have to wait till they open.
Sep 28, 2017 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Hi there i have old baxi boiler i was wondering
pilot has to be on all the time on this baxi ,piolt might be a bit large might need adjusting down
Oct 05, 2009 | Combi Centre DX - Mango
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
My daughter has a Baxi Combo 105e fitted with an optional timer. I believe that the timer is possibly a Grasslin although it has no name on it. Although the clock goes round, the Central Heating doesn't...
I have a Baxi Combi 105 HE boiler that has just been fitted and it has the optional 7 day digital timer but no instructions on how to set it does anyone know where I could get them from. Many thanks
Feb 21, 2009 | Hardware & Accessories
Hardware & Accessories Logo
2,571 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
