JBS Airmaster Split System 1.5hp is automatically shutting down
After trouble shooting the remote for this unit for the better part of the day... there has been no success in keeping this unit on.
In some instances the unit's compressor is shutting down... effectively producing no air. Pressing the on/off switch then effectively shuts the unit off completely until pressed again to switch back on, in which case the unit briefly ''comes alive'' only to repeat the process about every 5 minutes or until your own patience wears out.
In other instances the unit is shutting down completely.
The batteries have been changed, their is a stable mains supply, the compressor appears to be functioning as normal and the full setting options of the remote have been explored.
Also, I would like to understand how to reset the clock to the correct time?
Thanking you in anticipation and kindest respects for your time.
PS It would have been great to see this unit listed in the product list. It is probably there, but without the character for character wording is impossible to find?
  • 3 Answers
JBS Air conditiong went bust early 2007. but there is still ways to get around this. you can try switching off the mains to the unit for about an hour then back on see how this goes as it resets the electronics. common fualt with JBS. other wise you can contact me on 0412 844 991 as i still have some contacts that may be abl to help you out.
Posted on Nov 17, 2009
  • andrew_gr267
    andrew_gr267 Feb 28, 2012
    Please don't call. I am no longer able to help
  • andrew_gr267
    andrew_gr267 Apr 12, 2014
    What part of DONT call do people not understand
Buy a new one parts etc long gone
Posted on Feb 28, 2012
  • 49 Answers
If your JBS air-conditioner is having electrical control problems,aybe our replacement controls can help. see us at digitalcontrols.com.au or 61418751691
Posted on Feb 23, 2011
  • andrew_gr267
    Please don't call. I no longer am able to help.
  • 4,655 Answers
This is a close as I have been able to get your sources and information. I hope the link and the company will give you the answers you need. Anyway we will give it a try? Click the link below and please let me know if you were able to resolve the problems mentioned here at FIXYA
Let me know and Thanks
http://www.airmasters-ar.com/webapp/GetPage?pid=109#Source%20List
Posted on Feb 02, 2009
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
Lg split system wont stay on
When the freon is low the unit will start. When the compressor starts the low pressure side drops and shut it off as the high pressure rises. The low pressure switch shuts off to protect the compressor when there is not enough freon to carry the oil to lubricate it.
Oct 18, 2014 | Heating & Cooling
Split System Error
so like a faulty component look up Fujitsu web sight for trouble shooting should have answers on there web sight
Jan 03, 2014 | Fujitsu Heating & Cooling
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
We have a 24DMC split air conditioner and it will not start up. The green light on the wall unit flashes 3 times followed by the orange button flashing 3 times. Can u please help?
A repairman just left and the problem is, I think resolved. The solenoid on one of the mini-split units was malfunctioning. It was telling the units that it was open and functioning but was actually not working for one of the two units, and caused the main unit to shut down. Once the problem was isolated and the unit fed by the faulty solenoid was shut down, the other unit functioned perfectly. So we now have half of the cooling for the house, but better than none, until we can get the part and install it.
Jun 28, 2011 | Comfort-Aire DMC24SB Split System Air...
Brand new LG mini split,24,000 BTU. One indoor unit is freezing on first start up but not the other.
That is a typical indication of a low charge of freon....
Check the charge and also for a leak in the system...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 19, 2010 | GE Quiet-Aire Ductless Split System Air...
Cooling shutting off green light flashing!!!!! its hot here in australia
Hi, Not knowing what kind of a/c unit you have I can give you some things to check out that may get you back online.If this is a split system, indoor and outdoor unit, always check for power first. Check the outdoor unit as it is on its own high voltage box.It sounds like it is a ductless split system, controlled by a remote. If you have a manual, try going through the trouble shooting section of the system.This Heat may have shut the outdoor unit off, the compressor due to high head pressure? If the fan is running, listen for the compressor and see if it is on also. You can kill the power to the outdoor unit, and take a water hose and wash the dirt from this coil, being careful not to bend the fins.If it is off on high head, this will bring it down and hopefully run and cool for you.Please get back to me with more Information on the type of system that you have if I haven't got it right.Try doing what I have recommended also, step by step. Sincerely, we can get this up and running for you, if you get back to me. Good Luck,
Shastalaker7
Nov 12, 2009 | Heating & Cooling
Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
May 08, 2009 | Sanyo 18KS52 Air Conditioner
Heating & Cooling Logo
1,544 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
