Question about Samsung SyncMaster 940MW 19 in. LCD Television
Syncmaster 940mw , there is no power
It will not turn on, the LED light indicating that the monitor is on does not come on. how do fix this? I have checked the cable and it is fine. may be the on/off switch. The remote does not turn the monitor either
  • 2 more comments
  • Anonymous Mar 07, 2009
    i have the same problem :(
  • Mitch Valdez Mar 19, 2009
    Yep, mine is doing the same thing. The problems started with me having to push the power button over and over until the green light stayed on, but now the monitor won't even power on at all...
  • Anonymous Apr 06, 2009
    after 4 years, now i start having the same problem. It is still working thought, but i have to repeatedly pushing the power button.
  • joemobility Apr 15, 2009
    yep...same thing here. What I did notice in the past was I would unplug it, wait 10-15 seconds and then plug it back in. I would watch the green power lite blink 1 time. Then I could power on the TV. If I don't get the single blink, then the TV won't power on. This is where I am now. I will l eave it unplugged for over a day...when I plug it in, no blink and no power on. I've try outlets in the room.
Hiya, not sure if you've sorted the problem or not. But my father is an experienced TV engineer and he had a look at my monitor, with the exact same problem as you.
Where green power light either does not come on or it doesn't go 'solid' so therefore the monitor does not switch on. And I must keep trying until it goes blank for it to work!
He said it's the Capacitor which is not functioning properly and just needs replaceing. And that in future, it is recommended to never leave the monitor on standby, as these problems may occur again..
Posted on Sep 20, 2009
I have the same problem. I dismantled it, and there are broken/exploded capacitors on the power panel. If you replace these, it will fix the problem.
Posted on Apr 17, 2009
  • Samsung Master
  • 1,684 Answers
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 19, 2010
I have samsung syncmaster 940mw monitor. The monitor for the most part will not turn on. When the power button is pushed or attempt to turn on with the remote the little green pilot light will blink or...
That is a hell know problem with the 940MW tv/monitors. The power supply has failed because of parts called capacitors have shorted. If you can solder then you should be able to repair your monitor. Here is a link to the repair guide for this issue.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps, if so please rate my solution.
Oct 30, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung SyncMaster 940MW 19" LCD Monitor keeps going blank
Before you spend a lot of money on the unit look over this article we have posted on our web site: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ If you can solder then you should be able to do the repair yourself. The power issues you have are usually caused by a failure in the power supply board. If you don't want to do the repair we do offer repair services, more details on this can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solutions.
Buddy
Corporate Computer
www.ccl-la.com
May 03, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Problems with Samsung SyncMaster 940MW 19 in. LCD Television. Wont turn on, little green light flickers once when I press on button then nothing. Please help me :(
Buddy
Corporate Computer
www.ccl-la.com
Jan 06, 2010 | Samsung SyncMaster 940MW 19 in. LCD...
Samsung 940mw monitor ringing then blank screen
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com Look on the monitor repair page 2. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Samsung SyncMaster 940MW 19 in. LCD...
Power light was blinking took a long time to turn on, now power light does not blink or go solid and screen does not work
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com This model is on Monitor repair page #2 We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung tv monitor 940mw
Buddy
Corporate Computer
www.ccl-la.com
Aug 18, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Green power indicator under on-off button blinks repeatedly when trying to power up and it takes 15-30 seconds for monitor to turn on.
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or slow turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
May 09, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung-SyncMaster-940MW power problems
I experience the same "power on" problem with mine, bought february 2007.
Just called the Dutch servicedesk of Samsung Electronics, just gave the serialnumber, next tuesday I will receive a new monitor.
Thumbs up this time for Samsung service
Sep 02, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsunng 940mw lcd monitor will not power up. was blinking several times before it would turn on. now no power light nothing.
Jul 21, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung SyncMaster 940MW 19 in. LCD Television Logo
447 people viewed this question
Henry  Thomas
Henry Thomas
