Question about 2wire (1000-100016-002) Wireless Adapter
Can't access 2wire network using netgear adapter
I am unable to access my 2wire wireless network using my netgear wireless adapter on the second computer. I am currently at the stage where it asks for the WEP key and confirmation, I type them in ( and I have check for accuracy multiple times) it tries for a little under a minute and fails to connect without any error message as to why. When I attempt to repair the connection it cannot and fails at the "connecting to wireless network" step. Please, any help would be greatly appreciated and the sooner the better. Thanks.
  • kevin_langst Feb 02, 2009
    Thanks, ronraz, I am responding from said 2nd computer so it definitely worked. The whole reason I had to restart the network up from scratch however was it had been hacked due to lack of security last time. Any advice you can give on implementing either WEP or WPA without it messing up the wireless connection to this second computer? Thanks again.
I was also having trouble with my Netgear wireless n USB adapter connecting to my new at@t 2WIRE gateway. The problem was that the netgear software wouldn't allow my computer to stay connected to my 2WIRE gateway and the software wouldn't allow Windows when restarting my computer. I have Windows XP and after hours with at@t support there was no resolution and they gave me Netgear's suport number to call 1-888-638-4327. After 10 min. the problem was fixed. They had me click start icon at bottom left corner then all programs, then highlight "start up" and if you see anything like netgear adapter or netgear start up wizard right click on it and click delete. That was it! rebooted my computer and it connected automatically!!! I'm not very computer knowledgable but I hope this helped
Posted on Jul 16, 2010
  • harvardguy Mar 16, 2011
    Because of nena10, I unplugged the computer that had been connected to the netgear, rebooted the netgear (by unplugging for 30 seconds) then plugged in, and now my 2 wire connects with no problem. The computer that I unplugged from its ethernet connection to the netgear router is a mac, so I don't know where the startup settings will be, but when the mac owner returns tomorrow I'll tell him that my 2 wire NOW sees the netgear, and therefore what is the mac doing when it's booted on, that causes my 2 wire to NOT be able to connect. Thank you nena 10.
    Problem Solver:
  • 13 Answers
Maybe it's the the router wep key, so let's try to remove the wireless security from the router then try to connect, if the problem solved try to but another type of security on ur router ex.(WPA), if not try to uninstall ur wireless driver then install it again but without any other application for the wireless, cuz some times the wireless driver install support wireless software that conflicts with windows wireless manager.
i hope this was usefull
Posted on Feb 02, 2009
Windows unable to find certificate to log on using netgear wna1100
Windows doesn't need a certificate to logon to the router.
It may need one to logon to a web page.
Check by accessing another web page.
Dec 02, 2013 | NetGear WNA1100 WirelessN 150 USB Adapter...
Netgear adaptor won't recognize 2wire 420
If you wish to unlock this Huawei E960 password.... Call +2347035041294... Skype: mickyhandsome2010
Oct 17, 2013 | NetGear WNCE4004 IEEE 802.11n 450 Mbps...
I use 2Wire router and usb adapter. I switched
you dont need to install the driver for the 2wire, you just need to configure the computer to look for the 2wire, if unable to locate the 2wire from your computer, there is a problem on your 2wire it self
Jun 13, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire wireless usb
You just go to network connection and select your network connection. Just right click to it and go to properties. Configure it which suits you best (Do it if you know about dialling rules and near by dialing environment ie if this support the high speed prefer high speed and it support low spped then do low spped as it optimized the network utilizations.) You can also use network utilization tools available in tune up utility, etc whichever availabel in market.
May 31, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
Unable to connect to wireless network
Re-Enter your wireless key correctly is normally what thats means
Mar 15, 2009 | NetGear WG311T 802.11g/b Wireless Adapter
File sharing problem after installing Netgear DG834G ADSL/Wireles
- Run the Windows Network Wizard in each computer on the network.
Mar 10, 2009 | NetGear DG834G Router
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Dec 12, 2007 | 2wire HomePortal® 1800HW Router...
2wire (1000-100016-002) Wireless Adapter Logo
843 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
